I have a 2008 Roadtrek Agile SS we purchased new. Up until recently the Onan 2.5 KVFA propane generator always started with the remote switch. The start function of the remote switch does not work. The generator starts utilizing the start button on the generator itself, runs great and will produce power to the rv. I can shut the generator down but using the stop function on the remote switch.
I have looked for a wiring diagram with voltage and ground indications but so far have not located one. If anyone has one please add it to the comments.
The remote switch is also connected to a time meter. When the generator is started from the switch on the generator it records the run time. The time meter and the LED on the remote switch function while the genset is operating.
Using a volt/ohm meter and the generator not running, I have a ground on the black wire at the switch. A ground on the red wire at the switch. 12volts DC on the brown wire and a ground on the yellow wire when the stop function on the switch is depressed.
With the generator running the same conditions apply except the red wire is energized with 12 volts DC to run the time meter.
I would appreciate any additional troubleshooting hints before I head to a dealer.
Dick
Dick
