Hello,Looks like a good diagram. Any chance of posting a higher res one? I can't actually read the text.
Winter is here, we have snow on the ground.Hello all,
I finally did the modification today and in doing so I found the answer to all my questions.
First:
In step #6, of the original post, you really have to add a terminal inside the female connector. The male connector has 2 wires(very hard to see) and the female connector has the 1 wire (black blue white dot) please note that you don't tap into that wire but you add a terminal and a wire into the connector, this will give you access to the second wire to activate the fan.
Second:
You must use a SPDT (single pole double throw,last relay to the right in my diagram) relay to control the Espar unit, when the relay is off the Espar works normally, when the new switch is 'ON' the ESPAR start running, see my diagram for details
I have everything running fine, the Espar unit fires up, the water pump goes on and the fan works.
I am very happy with the mod, this will replace the block heater that I needed to install in order to easily start my Sprinter this winter. I will be heading south in February and I don't want any starting problem before leaving.
Thanks for diagram, as I been wanting to do this. BTW, do you know how long heater can run before main battery would not have sufficient energy to crank engine?Hello all,
First:
Second:
I am sorry I don't know how long but if you have a good battery, it should be able to support it if you run the Espar unit for 10-15 minutes only before cranking up the engine. A battery charger, hooked up to the main battery, may help run the unit for a long time.Thanks for diagram, as I been wanting to do this. BTW, do you know how long heater can run before main battery would not have sufficient energy to crank engine?
I was thinking about hooking 12V source to an auxiliary battery if not long enough.
For an example, the aux. heater in my NCV3 will run 20 minutes before it automatically shuts down. That is the factory recommended time for warm up, before the battery gets too low. The heater itself doesn't use that much current after initial startup, but the electric water pump and the fan do.Thanks for diagram, as I been wanting to do this. BTW, do you know how long heater can run before main battery would not have sufficient energy to crank engine?
Hi Zed,Thanks Lepapehermann.
I'm wishing I had gotten to doing this already. It's getting colder here by the day now. I don't really need to be running the sprinter right now, but it's always a bummer having a vehicle sit in the driveway not being able to start. As soon as I get some time and the weather gets such that I feel like shuffling enough vehicles to get the sprinter into the shop I'll be working on that mod. I'm sooooo looking forward to an engine preheat.
PS: I bought the 3 SPST relays over the web from Princess Auto. I am sure you know them, they are based in Calgary (http://www.princessauto.com/)First:
Second:
OK, here's a bit of dumb question. I've done some searching but didn't find the answer.
How do you get the switch insert panel out of the dash?
Hello all,
First:
Second:
Yes, you can leave it out and you will not lose control over the fan in normal operation.thanks to everyone that has contributed to this great thread.
I have all the relays 3spst 1spdt and connectors to do the mod. I will be setting it up to run of my house set 400ah. and will be using it as engine pre-heater and am not relay interested in having the heater fan running all the time as i have installed the Espar air heater.
My question is do i need to leave the fan relay out in order to not have the fan on all the time when the boost heater mod is on, or is the fan relay only powering the existing fan control switch. it looks to me like i would loss control over the fan
Being relatively new here, and looking through all the old stuff, it was nice to come across this a few nights ago. This is a mod that will be happening before the blusteries hit hard in December.
A few questions for you, Lepapehermann, or anyone else. I really like the factory switch and plan to use it. Do you see any issues with your wiring diagram to follow the original write up for connecting it?
No, you can certainly use the factory switch I used a different switch simply based on availability.
I'm thinking yours shows a better description of the relays. Also, I think if memory serves, there are enough empty slots under the seat to install all the relays there. I know it's more work, but it just seems so much more sanitary.
I don't know
Finally, I'd like to run the mod off aux battery power since I could see using it overnight occasionally.
Very good idea
Years ago I had a South Wind gas heater hooked up on my tractor trailer rig. It ran many nights including the big blizzard in '78. It was always nice not to have to run the motor.
