I replaced the Morningstar ProStar MPPT with a Kisae DMT-1250, swapped out our 2x Group 31 115h AGM bank for a single Renogy 170 Ah LiFePo4, and replaced our starter & aux lead acid's with new
Napa/Deka 9AGM49 AGMs. All our old batteries were aging, the SLAs were on their last legs and the main bank AGMs were definitely showing diminished capacity. Haven't had it out on a trip yet, but everything seems to be working as hoped after a week or two of testing.
The DMT-1250 is set for a 35a charge rate which matches the recommendations on the LiFePo4, and should keep the alternator draw closer to the 40a mfg recommendation. I'm hoping to baby this setup and get a long, reliable life out of it. The Renogy LiFePO4 is pretty new to the market, so it's a bit of a gamble, but we were unwilling to go with a single 100 Ah LiFePO4 and dual 100's were out of the budget. Time will tell if this was a smart choice.
The Renogy battery is likely a
relabeled Chinese OEM battery as available on Alibaba for $950 shipped. The cell construction (3.4 Ah IFR26650 4S53P, weight, size, appearance and BMS parameters are all identical. However, the Renogy is $1349 shipped from Amazon and comes with a prorated 5 year warranty, while the Chinese one has no warranty, probably takes ages to ship and if it arrives damaged, good luck. It's a bit early to say much about it, the physical build quality seems fine, it's half the weight and roughly the same size as one of the Group 31 AGMs (fits in the same battery box). It takes a charge and seems to hold it, other than that it's too early to say much else about it.
The DMT-1250 I'm pleased with. The interface is very simple, has a basic LCD UI. I won't buy the remote when it is available, I don't see it being very useful once setup, as I'm running the output into two of the 25a Pico shunts, so I can see the current output which is all I really need. It is nicely configurable, so I'm running the Renogy recommended 35a current/14.4v bulk and 13.5v float with a conservative 7 amp termination current. The CH2 (alternator input) is connected to my aux battery, so that can act as a buffer. So far, when charging at 35a, with a fully charged aux battery, it continues charging ~10-30 minutes after ignition is terminated, which is great (until the AGM drops to 12.0v). I figure when the LiFePO4 is fully charged, I can go quite a bit longer than that in float and power supply mode, which allows the Aux to effectively be the first tier in discharge before isolating to the LiFePO4. With a low discharge rate, this might allow us to use somewhere up to ~50% of the AGM capacity before it cuts off, which is just about perfect.
I'm planning on wiring up a
Blue Sea 2146 SPDT with a small relay for full control (always-disconnect, auto, always-connect) to allow for combining the starter and aux AGMs with the engine off, which would let us tap into ~50% capacity of both starter and aux, which would cut the discharge current to half and let us more effectively tap into the AGMs. Can't think of a downside...
Rob
