HAR HARthe flux capacitors
New owner of a complex vehicle with way more parts than anything I've worked on prior and learning as I go with thanks to helpful people on the sprinter forum and reading countless posts to educate myself better on how to maintain and service with what will hopefully someday be my new home.What do you think you are regening ?? The T1n's don't have DPF.
Sure, but can't you do that with the 802 device?The 808 pro read all the systems even ones like the radio that the snap on scanner did not access. I also was able to clear the oil change interval with it. I am happy with it so far the live data is very nice.
Thank you! This is exactly what I wanted to know!Today I finally talked with an Autel tech that said for the 2002 to 2006 Sprinter the 808P cannot do anything extra that the MD802 can and that the 808P was designed to also work on newer vehicles.
Welcome Tony and hope this helps for others:Thank you! This is exactly what I wanted to know!
The MD802 cannot activate the ABS module.Can either units activate ABS modules?
This is the function list of MD802 All system and the MD808 Pro:
MD802: http://download908bak.auteltech.net..._sprinter/en_MaxiDiag_E_Sprinter FUNCLIST.pdf
MD808 Pro: http://download908bak.auteltech.net...nter/en_MaxiDiag_E_Benz_Sprinter FUNCLIST.pdf
It says it can access ABS, but unfortunately doesn't specify to what capacity it can interact with these modules.Welcome to the forum Absalom! It helps others to help you if you'll simply add your vehicle information in your signature.
This may also help you see what either unit can access:
Looking on the AutelTech website I cannot find an applicability list for the MX808, the nearest is a spec sheet as a download from here...This is super helpful. By any chance do you have a similar sheet for the MX808 (android based one)?
Rob
OK, thats all I could find, I assumed it was cuz I don't have access to the customer support archives, as I'm not a current customer.Looking on the AutelTech website I cannot find an applicability list for the MX808, the nearest is a spec sheet as a download from here...
https://www.auteltech.com/autelcms/Specialty Products/555.jhtml
