john_ooten
Hello all i have a 2008 Frightliner Sprinter 2500 high top w/ 3.0L MB diesel motor and it seems too HATE the cold weather ... i replaced 4 of the 6 glow plugs about 6 weeks ago was afraid of braking the last 2 .. i got all 3 out on the drivers side and the front plug on the pass side but the mid an rear were in there good! I soaked them an was gonna try again but never got a chance. It seems that any temp below 12 degrees and it will not start! i have a 200w Magnetic block heater i stick on the side but with everything being aluminum there is only one place it sticks it helps a little but I hate worrying if my van is going to start in the morning it really wears on me!...
I had someone tell me that there is a built in block heater that it just needs wired up, anyone know if this is true?
I used to have a F350 that i plugged up and it started NO matter the temp! i would love to have the same confidence in this van!
I do use anti gel fuel additive. i have looked into getting a "pad heater" for the oil pan or fuel filter but to be completely honest i do not fully understand what is preventing the van from starting .. the fuel or the oil? Someone also mention a recirculating heater that attaches to the radiator may be available for my van.. anyone used one or the pad heaters with luck?
If there is a block heater built in that just needs wired that would be great but if there is no such thing what is my best option to ensure it will start? (No garage) I'm sure someone else has had the same issue as i'm in Ohio and it gets a lot colder up north! Any info would be great!
Thanks in advance for any help.. stay warm!
John
John
