seans
I'm still looking for one of the earlier posters (or anyone) who has disconnected the tranny lines so they can swing the radiator out for a better view of the engine, whether they get a drip or a geyser of tranny fluid, and what tricks they use (if geyser) to plug the pipes temporarily. (I can think of plenty of ways to plug them, but would rather hear someone else's better idea.)
Hi talkinghorse,
I found out that disconnecting the metal tubes at the radiator is a Bad Idea by searching before I made my original post:
https://sprinter-source.com/forums/showthread.php?t=3168
https://sprinter-source.com/forums/showthread.php?t=8406
Autophysn doesn't say it directly in his very informative post earlier in this thread, but his instructions about using a 17mm and 19mm wrench can only be done where the metal tube meets the rubber tube. [I'm pretty sure he means #3 and #4 in the image below.] If you are very careful holding the 17mm wrench steady, the torque applied on that tube when loosening the 19mm tube should be minimal, and because of the length of the tube, the fittings on the radiator should be fine (crosses fingers).
In fact I've loosened one of these a little (#3 - it went pretty well) and before things started leaking I decided to go inside and Ask The Sprinterweb.
[Edit: #4 - mostly hidden in photo - was VERY tight and I've left it connected for now. I'm not touching #1 and #2 (hidden behind tube) because of the posts above.]
But I'd like to hear from someone who has disconnected the radiator to get a clear view of the components at the front of the engine. I want to see if I have a leaky high pressure fuel pump, orcracks in my harmonic balancer*, which is why I want to get the radiator out of the way and get a good look, directly, cleaning parts and eyeballing it, using a magnifying glass to look for cracks (which is a sucky way to detect fatigue - anyone got a better idea for a part in place?)
*[Edit: After re-reading the Harmonic Balancer thread and being reminded of the failure mode where the balancer shears off around the washer, I'm not going to count on being able to see cracks beforehand.]
Hi talkinghorse,
