T1N OM647 Engine Coolant Pump Replacement
2004 2.7L Water Pump Replacement
5 cylinder water pump leak leaking remove replace change install
190,000 miles. Slight coolant drip from seal. The pump didn't "fail".
Added:
The 2006 pump made it to 195,000 miles and September 2021. The 2006 pump also had a coolant drip. The pump didn't "fail". The shaft of the removed pump did have some play. The new replacement pump shaft had no play at all.
Cost
Approx. $200.00 w/ a metric Allen set.
Parts
Water pump w/ gasket. The OEM pump MB 6472000101 has a metal gasket. Other pumps have a composite gasket. Metal gasket = easier cleaning. Added: The metal gasket also provides a set spacing. I prefer the metal type.
Caution: There has been a warning about replacement water pumps having an oversized bore for the idler pulley self threading fastener. Double check that the bore is correct. Some info is here. Thanks goes to Lightguy.
https://sprinter-source.com/forums/showthread.php?t=25041
GO5 Type Coolant. About 2 full mixed gallons without a complete system drain/flush. I used Zerex GO5 Formula Phosphate Free from NAPA. Advanced Auto didn't carry any GO5 product. They were insistent to use one size fits all. I don't recommend that.
Smaller size outlet gasket or RTV sealant if you re-use the existing metal gasket. This gasket is between the lower pump outlet port and a small outlet manifold. No new small gasket came with my OEM pump. No stock at the dealer when I called on a Saturday. I re-used the old metal gasket with RTV.
Gasket 647 201 00 80
Interchanges 221 33024 001, 22133024001, 647 201 00 80, 6472010080
Tools Necessary
Typical hand tools most anyone has plus:
10mm socket or wrench (turbo heat shield)
CR-VT-20 Torx
CR-VT-25 Torx
CR-VT-30 Torx
CR-VT-45 Torx (for outlet manifold bracket)
8mm Allen (for fan bolt)
CR-VE-10 Socket
CR-VE-12 Socket
CR-VE-14 Socket
Torque wrench
Hose removal tool
17mm (or 18 mm?) 12 pt. (offset box wrench for belt tensioner)
1/4" 12 pt. box wrench (for outlet manifold pump bolts)
T20 Torx screwdriver (for lower grill screws)
Ultra Blue RTV Gasket Sealant (if re-using outlet manifold gasket because none was included)
Wooden block 6 3/4"L (for propping radiator forward)
Remove frame bar to tilt radiator forward
Disconnect the battery negative.
Remove the fasteners holding grill. Loosen the two lower screws with a T20 Torx screwdriver first. The plastic frame holes are slotted.
Remove the heat shield above the turbo.
Remove trim panels below the headlights.
Remove 4 ea. fasteners, remove the headlight pods. Disconnecting the wiring is not necessary. Swing out of the way.
Remove 4 ea. fasteners on frame. Pop 2 ea. clips. Remove the top frame and stand it on end.
Caution. The pump bolts are different sizes and lengths. Be very careful when small bolts are torqued. The large bolt value can break them.
The manual I have said to remove a hose to tilt the radiator and remove the fan and shroud together. I found no need to remove any hose or the fan shroud ever. I did pop the 4 shroud clips. One on the right rattled down to where I never did find it. MB over-engineered that anyway so I only need 3 clips. At least that's my story and I'm sticking to it.
Drain the coolant
With the headlight pod removed you can more easily access the tank drain. It is hidden pretty well in the lower support structure. I made a hose unit per HKPierce. It helped, but I think anytime I drain the coolant in the future I will remove the grill and headlight pod for access. Turn the valve open to drain. Find it by feel. Added: Don't bother. The drain drains so slowly it isn't worth the effort. Catch the coolant when the pump hose is removed. A bit messy, but less aggravating.
Remove the fan
Pull the radiator out forward for access to the fan and pump. I wedged a 6 3/4" wood block to hold the radiator out and keep access. It worked very well, but it did slightly bend the aluminum top frame lip. I do mean slightly.
Remove the 8mm Allen bolt to remove the fan and viscous clutch. Righty tighty, lefty loosey works on this one. I was able to wedge a 3/16" x 10" square shaft screwdriver into the bolt heads for the pulley to hold the shaft. The real tool designed for that would be nice. I was able to carefully extract the fan assembly with the shroud in place.
Caution: Keep the fan/viscous clutch upright when you store it. Do not lay it flat.
Use a really small screwdriver to pop the plastic cover off the idler pulley that is on the turbo side. Remove the idler bolt using the CR-VT-45 torx. The same size as the frame screws.
Remove the bolts from the water pump
I made a cardboard bolt holder as a guide. It helps keep the bolts organized and makes it easier when re-installing. I used a CR-VE-12 socket to remove all of the bolts, but there are actually 2 different head sizes. By carefully using the incorrect CR-VE-12 socket on the far right 6mm bolt I avoided needing to remove that idler pulley. Be very careful when removing the top bolts hidden from view. It is very easy (at least it was for me) to remove a wrong bolt that is not for the pump. (Use the cardboard diagram. 9 bolts.)
Disconnect the hose and manifold
I tried to loosen the top short hose from the pump without success. The small end to the pipe removed easily.Then came the two manifold bolts. I removed the front, easy one first which was a mistake because then the loosened manifold bound against the back bolt. The rear bolt is very difficult to remove. I only had a deep CR-V-E10 socket that wouldn't go in. I'm not certain a shallow socket would have helped. The turbo is in the way big time. I used a 1/4" 12 point box end wrench to painstakingly turn the bolt out 1/8 of a turn at a time. The whores and bastards came by to help out. Why MB didn't rotate the bolt pattern for access is beyond me. It is only 2 bolts. You'd think the position could have been better selected. (Sorry. Whining over.) - Remove and reinstall the pump and attached pipe manifold as an assembly!!!
I didn't do it this way, but this is what I'd try:
Remove the pump with the small hose 2 bolt manifold connected
Leave at least two bolts holding the water pump in place.
Remove the small hose from the pump outlet manifold.
Underneath, remove the large hose from the manifold. Be ready to catch coolant.
Disconnect the pump manifold support bracket.
Remove and support the water pump to get access to the manifold bolts.
Remove both manifold bolts.
Remove the water pump.
Clean gasket surfaces.
Once the pump was out I used the 3/16" square shank screwdriver to wedge the pulley bolts and remove the 4 ea. CR-VT-30 screws. With screws out I held the old pump shaft down at about 6" height and dropped it on the cement to remove the pulley. Two drops and the pulley popped right off. Not elegant, but effective.
Installing the new pump
Install the pulley on the new pump.I installed the pump with the manifold hoses still connected. This created some real problems for me so I don't recommend that method. The manifold pushed against the pump and moved it over. That made it difficult to start the first bolts. Once the pump was in place I struggled to get the back manifold bolt in. When the whores and bastards again stopped by (this time with the mother#%$@^!'s for extra support), I stepped back for a bit. I finally ended up disconnecting the manifold hoses and bracket to get the rear bolt started. It was still difficult to start that rear bolt with the pump bolted in place.
I did it this way on the 2006:
Install the pump with manifold pipe completely connected
Use sealant on the small gasket if it needs to be reused. Before removing the reducing elbow hose, mark it for position. Install the reducing elbow hose on the new pump with the spring clamp.
Position the manifold/pump assembly down between the radiator and engine basically in place.
Install the large hose and the reducing elbow small end hose on the pipes. (Don't tighten hose clamps yet.)
Position the pump gasket on the pump using two top bolts to hold it basically in place. I also used a piece of electrical tape to help hold the gasket. Pull the tape loose once the pump is held with a couple bolts.
Install all the bolts from the cardboard template.
Torque the pump bolts. Being careful again to get the correct bolts on the top. 6mm = 10 ft/lb. 8mm=15 ft/lb. By carefully using the larger CR-VE-12 socket on all of the bolts I avoided needing to remove the smooth idler pulley when torqueing.
Rotate the turbo air intake sensor back to original position if you moved it. (Not needed for the 2006.)
Install the manifold bracket bolt in the alternator. (3/8" 12 point wrench fits the bolt.)
Tighten the 3 hose clamps.
Install the idler pulley with the slightly triangular thread forming bolt. Torque to 26 ft/lb.
2011/07/03 edit: Do not tap the hole for the triangular bolt. The self thread design is for better holding. ("The term for the 'thread forming' feature is trilobular." Roger - Sailquik post #26)
Snap idler cover back on.
Install the serpentine belt before the fan is in the way.
Install the fan/viscous drive. I didn't like the way the 3/16" screwdriver wedged against the viscous drive for tightening, it seemed fine for loosening. I used a large rat tail file tang to wedge the pulley bolts. Wear gloves to hold the file because they are brittle. The tang bent a bit, but it worked fine. As I didn't have the torque spec I made the bolt reasonably very tight. The proper holding tool would be nice to have.
Close the radiator drain if not done yet.
Replace the top frame member. I always grease bolts for reassembly. I also greased the bearing areas as my 2004 had rust bubbles there. A more meticulous person may want to grind, prime and paint. (The grease completely halted the rust.)
Install the 2 ea. radiator support clips.
Install turbo heat shield.
Install headlight pods.
Install lower trim panels.
Install the grill last. My one lower grill plastic was broken previously. I used a black cable tie on that side to hold things together. Doesn't show at all and works great.
Refill coolant per manual. I needed 2 gallons 50% mix. They say it takes about 3 heat/cool cycles for the level to stabilize.
Reconnect battery negative if removed.
Except for the back manifold bolt, the pump change is not bad. I think the job could be done in 4 - 5 hours. It took me two days, but I stopped to call the dealer net day for the small manifold gasket. The back bolt on the manifold also gave me fits coming out and going in. That added more time than I care to think about. My modified installation by disconnecting the manifold completely will help make that less of an issue. AP/vic
Thanks goes to Lindenengineering Dennis.
For OM612 Engines Only.
Added:
Cost
Parts
Tools Necessary
CR-VT-20 Torx
CR-VT-25 Torx
CR-VT-30 Torx
CR-VE-10 Socket
CR-VE-12 Socket
CR-VE-14 Socket
Torque wrench
Hose removal tool
Drain the coolant
Remove the fan
Added:You were wise to PM me with this question and location or I would have missed it.
There are 3 different fastener torque specs to use on the water pump. The 6mm pump housing hardware is torqued to 10 ft lbs. The 8mm pump housing hardware is 15 ft lbs. And the special 10.9 graded, thread forming bolt [TRILOBULAR™ ?] for the idler pulley mounting is 26 ft. lbs. Doktor A
Well if you do use aftermarket , just make sure it has a steel gasket not paper or cardboard one
AND
If yours is a 2002 /2003 do make sure the fuel pipe retentions clips are installed or replaced. Read important.
An OM612 engine specific Write-up is here:On a 2002 /2003 the HPOP fuel pipes run very close to water pump pulley.
New retention clips are essential being attached to the water pump.
In your case no worries.
OM612 water pump replacement
T1N OM647 Engine Water Pump Replacement OM612 2002-2003 2.7L Water Pump Replacement ]NOTE: This is an edit of Aqua Punta's OM647 instructions for water pump replacement. It is largely fine for OM612, but some parts are not applicable to OM612. So I have edited accordingly. HKP 5 cylinder...
sprinter-source.com
