Thanks for all the advice, I'll definitely give all this a shot!Might want to order a stick on (not magnetic as the oil pan is aluminum) oil pan heater.
Might find one at a local auto parts store, or they can order one in for you.
Also probably need to check the fuel heater inside the fuel filter.
Also might want to get some fuel anti-gel and dribble it into the line running to the
fuel filter.
Sounds like it's only getting a little fuel, when the fuel is heated.
Might also try a hair dryer or heat gun (on the low setting) and heat all the fuel lines
you can get at.
Might want to place your halogen bulb under the fuel tank or better still get another stick on
oil pan heater and put it under the fuel tank.
Be careful as the tank is plastic and cannot stand much heat without deforming.
If it fires up and runs fairly normally (even for 30 seconds) then the glow plugs and
starter would seem to be working normally, but as soon as the fuel pump (s) try to
pump the gelled fuel, it starves for fuel.
There is an electric pump in your fuel tank, with feed through the fuel filter and then
pushes fuel up to the high pressure pump.
Sounds like a gelled fuel that won't go through the fuel pumps or the fuel filter.
If you can keep it running for a few minutes, the return fuel from the injectors will
heat up the fuel in the tank.
Hope this helps,
Roger
Yeaaaa! Its ALIVE!!!! What SailQuick said. Sounds like gelled fuel at this pozint. Keep us posted..... (we're drinking coffee and avoiding the cold... but sharing your pain!)
Well, I gave up for the day, coffee and heat sounded too good! Now to get ready to toast the New Year! My resolution, get the van running!
