Sprinter Switch table/catalog?
marek42
Hello!
Is there an updated version of the table that was from Aftermarket Switch Table? The PDF is gone and even though I tracked down the guys new site URL the PDF seems to be gone from there. I managed to get the text of it from google cache.
Also I'm purchasing some switches and could add at least 1 part number to the table. Lets see if we can get this list back up in a more useful form on the forums here!
-Marek
marek42
Marek...I created a new one in the T1N Database section.
https://sprinter-source.com/forums/showthread.php?p=48886
It has more part numbers.
I have that document already, the nice thing about the now defunct PDF was that it had the switches re-listed as SPST, DPST, and wether they were momentary or not. I think it also had better pictures of what icons were on the switches... I'll post what information I have on that thread.
-Marek
99sport
This one?
I know I am resurrecting an old thread, but I found the table in post 4 EXTREMELY helpful. However, I have found an error in the central door lock switch diagram. Pins 3 and 8 are momentary switches to ground (pin 10). This is exactly what you need if you are installing an aftermarket alarm - you can use the OEM door lock switch (5103855AA) and the central timer mod (see https://sprinter-source.com/forum/showpost.php?p=189889&postcount=9)
The correct wiring diagram for this switch is attached.
