Its always been a challenge to get a place to hang out and eat in a van with factory seats. You went ahead and purchased swivels for your front seats but you still do not have a good solution for a table between your factory bench seat and the front seats. Boat pedestal tables are too small, put a hole in your floor and a speed bump that is a dirt catcher in your floor.
Everyone knows the Lagun table is great. It swivels out of the way, you can mount any type/size of table on it, and you can position it perfectly to get optimal use. The challenge was there has not been a way to mount it on a factory seat. The seat legs are angled, use thin metal, and its a small nightmare getting all the angles right even if you could mount one. So 20 hours later and several prototypes finally have a great solution for the ultimate seating set up on a stock factory van.
Here is an above view to show how flexible and perfect the table is. You can put a bigger table and off set it as well if you wanted more table space. It swivels around and moves forward and back- plenty of you tube videos on how great they are.
I will make some additional posts on how it all works, the bracket, and the install process to get everything perfectly aligned. (way harder than it looks)
