... The blank didn't fit in the lock at all, and after one was cut it still didn't fit in. Just a heads up for those looking to buy keys.
I have an Amazon listed brass key which didn't fit without modification.
My feedback to the seller.
Amazon purchase feedback
V. W.
Dear Sirs:
I ordered a key listed for Mercedes Sprinter Vito.
Keyecu Transponder Key Fob W/ Chip T5 for Mercedes Benz Vito Actros Sprinter V Class
I have 2 ea. VA or T1N aka 903 Sprinters.
The key arrived on time in good condition.
The key would not insert into my 2004 or 2006 model year Sprinter locks.
Using a micrometer I checked the outside dimensions and compared to my OEM key. The outside dimensions were the same.
The problem is that the center section of the key is not in specification. The groove area is too small which makes the center section too thick. I used an end mill cutter and key file to increase the size of the center groove/step and also reduce the thickness of the center section. The key now fits both the 2004 and 2006 Sprinters.
Your key dimension specifications should be checked against an OEM key to properly fit Sprinters.
vic"
I also submitted a poor review to Amazon which resulted in this response.
"------------- Begin message
Message from 3rd party seller:
Hello dear friend,
We just noticed you mentioned in the
feedback you write to us but never get response from us,we
checked all the message and don't found your emals,is there
any misunderstanding between us?
We could replace or refund for your
order,could you please send us a picture of your original
key blade to check??
Wish to hear from you as soon
Lily"
I saw no need to return the now working modified key.
Additional back and forth emails complete with pictures resulted in no real resolution.
I did a quick Amazon search. I could no longer find the key blank listing with my negative review.
Sellers/suppliers don't make key blanks. They source them. Apparently there are some out of spec key blanks being manufactured. Other than customer feedback on specific keys, I have no idea how to tell when a company would be supplying the out of spec blanks.
When you receive a blank try inserting the uncut blank into the locks. If the blank easily inserts into all of the locks it will be worth having it cut. Otherwise it should be returned before cutting.
Unless positive reviews indicate differently I would avoid Amazon keyecu T1N Sprinter key blank offerings. They supplied my out of spec key blank.
Added:
From a recent discussion.
I need help.
I bought an Ebay key with a RFD chip.
The thickness and pattern look good but it is too long.
That key looks familiar.
First, be certain that it will insert into the cylinders. Mine wouldn't without being shaved down with an end mill cutter and file.
When it is cut, every key should be indexed using the shoulder. Only hacks set up using the tip.
The extra length of that key is insignificant for Sprinter use.
Added:
I compared three of my keys.
It won't fit into the door because it is too thick? You might try filing the thickness down to see if it works. Others have had varying degrees of success in doing so.
If it was like mine, it is not "too thick". If anything it is thin and flimsy compared to my Ilco MB17 blanks.
The steps to the center are the wrong dimension. I used an end mill cutter in a drill press and a file to adjust that dimension. I never needed to adjust the overall thickness of the key.
I doubt that it is an Ilco brand key.
... One working key
A “hide-a-key” or a key that will only open the door is $3. For these keys we only need a good working key for duplication. The turnaround time is one business day.
If anyone goes through SOS for keys it would be foolish in my mind to not get at least a couple door only keys for 3 bucks each. for the most part that is cheaper than the blanks from many sources.
