I wanted to run an idea past everyone and see if my thinking is flawed, or if it might work.
I am primarily concerned with improving the ability to charge our batteries when away from AC power, as we don't spend much time with access to it.
We do not have solar yet, but will add it at some point.
So right now, primary charging is via the alternator. I am going to install a DC-DC charger to improve the efficiency and ability to charge the house bank from the alternator. I have a few options for this, and I have not made a decision yet.
Just to pass along my thoughts:
CTEK Dual: https://smartercharger.com/products/dcdc/ctek-d250s-dual/
Redarc BCDC1225D: https://www.redarc.com.au/dual-input-25a-in-vehicle-dc-battery-charger
Sterling BB1230: http://www.sterling-power-usa.com/SterlingPower12volt-12volt-30ampbatterytobatterycharger.aspx
Having read some threads on here, and Yahoo group, I was trying to think of a way to use the AC/DC converter we have installed for the air conditioner. I have not checked the voltage this converter produces, but hope it is > 13V. I saw some thoughts on the Yahoo group, but they involved adding wires direct from converter to house batteries, if I remember correctly.
If the converter does produce >13V, what would prevent me from when the generator is on, which is producing AC, which then turns the converter on, and produces DC, to feed that DC power back to the start battery via the existing wires connected to the existing relay? This would in turn charge the sprinter start battery, and assuming the voltage was high enough, engage the relay under the seat and also send power to the house bank (via the DC-DC charger, or even direct).
Obviously with the generator running, the 10A battery charging is doing it's thing also. This would take a long time of running to fill up the batteries which is why I am looking at a DC-DC charger which can put out more, ~30A. Not sure if the 10A charger needs to be taken off line, but I think they could run at the same time and feed 40A into the house back with the generator on.
This would require only minor changes to the relay/converter wiring so there was a way to feed the power back to the starter battery when the converter was running of AC. Even a manual switch could be used.
Right now the exiting AirCo relay will feed from the start battery (alternator) or the converter. So when in "converter mode", I don't see why that power could not also be fed back to the start battery via the existing cables.
Any thoughts/comments? Especially reasons why this would not work.....
