Wheels for the Sprinter
sikwan
06 T1N Can
The site...
http://www.rubicon-trail.com/G-Class/wheels/start.html
...lists the wheels for the Mercedes-Benz Gelaendewagen, but the bolt pattern ([FONT=Arial,Helvetica,sans-serif][FONT=Arial,Helvetica,sans-serif]5x130)[/FONT][/FONT] is the same as the Sprinter. You just need to make sure that you chose a rim that has an offset of 60mm. Less than 60mm, the wheel will stick out beyond the fenders.
A center bore of 84mm is a must also so that the weight of the van rests on the hub and not on the lugs.
Seek
