2004 T1N 133,000 miles. Recently changed my tranny fluid, filter, gasket etc including draining torque converter. Everything fine for a couple thousand miles. Tranny smooth and shifting normally. After a recent 600 mile round trip -freeway driving- when approaching home I got a little slippage in the tranny. Checked fluid level and it barely registered on stick.. inspection underneath revealed fluid spraying as far back as the fuel tank. I added about a half quart and realized It was running out fill tube ( filling too fast. So now I have additional fluid all over). Slowed down and added about 3/4 quart. Pulled it into shop and put it in neutral with parking brake on and could see a slow leak coming from torque converter ports. . Seemed to slow after a bit to an occasional drip. Rechecked the fluid level and now appears to be possibly over full. If overfill would I see the fluid coming out in the torque converter ports?. Any other ideas welcomed . I've searched around the forums but couldn't pinpoint this leak location. Tranny gasket and bolts all seem normal and no leak at connector. Thanks
