That's looking very nice. PMd you on the seats
Edit, no I didn't cos your PM isn't switched on! are the seats thec standard ones or is the driver's seat a bouncy suspension seat?
I thought the 312 could run vegetable oil anyway as they come standard with a fuel pre-heater?
Not that I've ever tried mind you.
i'd love more info on that if you would mate ?
as i'm in the middle of setting up a small reactor for wvo just now as it happens and also i run a 312 !!![]()
As i understand it the 212d, 312d and the 412d all have the same 2.9ltr turbo engine in them, i have a 412d. This is a direct injection engine with an elctronic injector pump. I'm not sure what engine is in the 312 so would not like to comment.
The signifigance of this is that DI engines do not run at all well when the engine is cold on wvo or svo, resulting in un burnt oil. I'm not sure about the fuel pre heater you mention, i haven't seen one on my engine although it would be handy to know what it looks like so that i can have a look. The danger of having unburnt wvo or svo is that it will gum up your piston rings which will both eventually cause loss of compression and also allow the veg oil to mix with the engine oil and this too can have some very serious effects on the health of your engine.
However once a direct injection engine is up to operating temperature it is perfectly capable of combusting wvo or svo properly. So the trick is to run 2 separate fuel tanks, one for diesel and one for your veg. A switching valve operating either manualy or remotely using the engine temperature for a swtiching signal is then used to switch over to veg once the engine is at temperature. Also at the end of your journey you need to remove the veg oil from the system and this is done simply by switching back onto diesel a mile or so before the end of your journey.
KS
KS,
The conversion looks great!
Since this has branched out to WVO I have some questions. I have about 10 gallons of peanut oil part of which was used to fry one turkey and then was stowed in our cellar about 5 years ago. Turkey frying is a bit more complicated than I thought. First let me say that I'm most likely going to dump it into a restaurant grease recycle, but if there is no danger I'd just as soon burn it off in my Sprinter.
My questions. Does anybody know if adding a quart of strained, unprocessed, once used peanut oil per fuel fill has any negative possibilities? I would expect with that dilution rate all should be fine. I'm thinking it will help with fuel system lube and let me dispose of my waste peanut oil.
Any and all thoughts are encouraged. AP/vic
