strange noise - help
dsellsbear
PAWS8IV
Previous to today I had not driven my sprinter if a few weeks. I have been waiting for summer to figure out what all is wrong with it. Glow plug light has been on and off for 6 months. I decided to take it for a ride and all was going well until I heard a very strange howling/whining noise coming from the driver's side footwell. I stopped, got out and filmed the noise. Please look and listen to the video and tell me if you recognize this issue. Thanks in advance. https://youtu.be/y9iRjLVo9cg
By the way
2003 Sprinter
199,985 miles
engine replaced under warranty at 98k by previous owner
intake recall performed 2 years ago
Tooth Fairy
Away with the fairies.
Alternator pulley?
In my little experience:
1.- Auxiliary bearings of the motor belt (tensioning pulley).
2 .- When I made the oil change to the hydraulic direction, by mistake I turned on the truck without oil, I heard a similar sound because there was no oil in the pump.
3.- With that noise, if it were the bearing of the water pump the water catch would be throwing water.
With a half-inch hose you put one end in one ear and with the other end you look for sound like a doctor with a stethoscope.
Does the sound appear in the engine compartment, or only in the footwell/cabin?
If only inside the Sprinter, then i'd wonder if one of the relays attached to Fuse Block 1 (under the steering wheel) was "making and breaking" at a rapid rate (that's how buzzers are made).
dsellsbear
PAWS8IV
Dick -
I think you are probably correct. I had a problem with my turn signals so I switched out the two relays at the bottom of fuse block 1 recently and the noise does seem to be more from the inside footwell area. I am going to mess around with the relays that I got off amazon and see if this fixes my new problem. relay.jpg
HELLA 965453041 Micro 10/20 Amp SPDT Relay
Is there anyone out there with good/bad experience with these relays?
Thank you all for the replies.
dsellsbear
PAWS8IV
Dick,
You were correct. The relays were making the noise. I pushed them in a bit more with a bit of a jiggle and the noise is gone.
Now I'm off to have the dealer change out my glow plugs.
I have the tall intake that came with the recall (don't remember if it is the same height as the old one) that I feel makes the replacing of glow plugs nearly impossible without removing the entire intake.
Thanks again.
