Some fun on the dyno with a T1N
2004VannaWhite
Big White Box
Testing my T1N today at the shop on the chassis dyno. I will post some stock and tuned runs later.
2004VannaWhite
Big White Box
We will be writing an EGR off and an EGR duty reduced file, along with raising boost etc.
2004VannaWhite
Big White Box
Stock and a mild power tune with reduced EGR.
Power is at the rear wheels, 6215 ft above sea level with no correction.
NB: it is very difficult to floor the accelerator without initiating a kick down at low revs. Consequently, some variance occurs between runs under about 2600 RPM (where the trans might kick down). Above 2600 the trans will not kick down and you can go WOT.
Try unplugging the 'Kickdown' switch on the accelerator pedal, it is the separate 2 pin plug. Looking at the wiring it is a normally open switch so simply unplugging should work.
Tooth Fairy
Away with the fairies.
2004VannaWhite
Big White Box
Scale your pictures down so we dont have to scroll backwards and forwards across the screen to view them.......:idunno:
Sorry [emoji52]. I was using Tapatalk and it image hosted and resized to what it considered "optimum".
Not uncommon. It isn't a big deal, just inconvenient for browsing. We get spoiled because the Sprinter-source attached pictures are limited to small enough file size that they fit within the normal window.
Thanks for providing the information. :thumbup:
rjz5400
Interested, in the egr tune out, without a power tune, for efficiency only.
This is a public service reduction:
