Oh--that bar doesn't show on the mobile version. Try this, if you don't care about cookies, etc. Clear your internet browser of cookies, etc., then close browser completely--shut down app. Reopen browser and type in sprinter-source address. Hopefully, you will have the regular display and not mobile version.Bottom of the screen, there is a shaded bar which has an unshaded open menu box at the left. Click on that box which has choices of default or mobile. Does that work?
I just tried that and even restarted the computer and when I signed in it immediately went to mobileOh--that bar doesn't show on the mobile version. Try this, if you don't care about cookies, etc. Clear your internet browser of cookies, etc., then close browser completely--shut down app. Reopen browser and type in sprinter-source address. Hopefully, you will have the regular display and not mobile version.
I am using a laptop, windows 10, and chrome browser maybe the easiest thing will be to just register as a new userQuestions like this are best asked in the "Questions and Suggestions about the Forum" area.. then the site owner (sikwan) sees them.
https://sprinter-source.com/forum/forumdisplay.php?f=18
Please tell us what mobile device you're using? Are you also using Tap-a-Talk?
(the other thing to do (i'm not seeing the symptoms, so i can't speak from direct experience) is to scroll down to the very bottom to see if there's a link/button to "display as page" kind'a thing)
I'm having this same issue currently. I can get rid of the problem for a couple of days by clearing all cookies, then I'm eventually forced into this horrible mobile interface.FOUND IT! (maybe)
On the top blue bar is "User CP" ... click that.
That will take you to the control panel.
In the left margin, click the "Edit Options" under "settings and options"
On *that* page scroll waaaay down to the "Miscellaneous Options"
The 2nd portion of that screen is "Forum Skin"
.... that option's drop-box offers: "Use Forum Default", "Default Style" and (ta daa!) "Mobile"
I recommend setting it to "Use Forum Default"
After you've made that change, scroll further down to "Save Changes" and click that.
good luck, please report results...
Thnks dick. This also fixed it for me. For some reason I got locked into mobile site on my desktop computer just by doing a forum search using the google search option. And there was seemingly no way of getting back to the normal view.TRY THIS!!!!
Start a forum session (i.e. log in to the forum)
By using THIS ADDRESS in your browser: https://sprinter-source.com/forum/index.php?styleid=1
(yes, you should be able to click that and with luck a "regular" window will open)
That should put you into "regular mode" ....
IF IT DOES then CLICK User CP,
then Edit Options in the left column, then scroll down to the Miscellaneous Options,
then scroll down in that to the Forum Skin section and use the drop box to set it to "default"
(don't forget to then scroll down and click "Save Changes"
good luck
p.s. the magic is the ?styleid=1
which tells the forum which style to use.... mobile is styleid 11
In fact, this link may do it all (change you to Default and drop you at the correct Options page):
https://sprinter-source.com/forum/profile.php?do=editoptions&styleid=1
Thank you, Dick,TRY THIS!!!!
good luck
