Aircraft Wrench
Backround
I changed the fluid 2 weeks ago, dropped the electrical valve body, drained the converter (I'll post my tech tip on that later) (Redline D4)
I installed 8 quarts of oil, ran the van in Drive up and down the road, measured the voltage, converted to temp and level....and had many problems getting the fluid up high enough....I even poured the old fluid into the bottles to confirm the amount....I then measured my homemade dipstick and found it not to reach the bottom of the pan...ARRRRRRGGH no wonder I had NO RSN because I had about 1 quart too much fluid I drained the fluid out to the level specified with the charts etc and drove a short trip (180 miles) and the RSN was horrible!!!!! I monitored the temp on the whole trip and it did not get above 1.61 volts
The day after I got home, I checked the fluid level again with the tranny in Drive, parking brake on and the level appears to be low I'm gonna add 1/2 quart (16 oz) and drive around some ...couple of days....
I'll post pics of my dipstick tonight etc...
So...anyone else noted level change issues? how did you deal with it? does installing more oil than the charts call for really show problems with "Foam" (level within the level below the planetary gear area)
