Help! Problems after reassembling dashboard
bcman
I"m in dire need of some assistance. I just took the whole dashboard apart, which meant removing Fuse Block 1 as well as the instrument cluster. I was installing a camera system and external audio amp, so I tapped into the ACC switched power at the radio, and B+ constant under the driver's seat (I added another fuse block for these items, but left the fuses out for now). I just got the dashboard, instrument panel, and FB1 reinstalled, and tried to start the car to test if everything was still working. I inserted the key, and turned the ignition to position I. Instead of getting beeping indicating the door was open, I got a single beep when I got to position I. At position II, fuse 6 in block 1 blew, and I had no instrumentation. The engine will start, transmission will shift into gear, but I have no tach, speedo, fuel gauge, etc, and no turn signals or wipers. emergency hazard lights work. I've got climate control, but no rear a/c. I've tried replacing fuse 6, but it blows every time I get to ignition position II.
Any ideas? I'm supposed to be on the road to pick up my wife in 2 minutes :(
One call a/c
You'll have to disconnect what you tapped into and see what you have from there.
bcman
So I disconnected the 4 power and ground connections I made this afternoon, and got a few changes: The single beep at Ignition position I stopped, and Fuse 6 stopped blowing at position II, although I still heard a 'pop'. Still no instrument panel, so I disconnected the instrument panel and cracked the case to see if the circuit board was fried. It looked fine, so I reassembled it and plugged it back in, and I got the door chime, and all the instruments came online! Everything was looking good. I reassembled the rest of the dash and drove to pick up my wife.
I heard a few more pops coming from under the steering column as I drove, but everything seemed to be working fine - turn signals, wipers, instruments. When I got to our meeting place, I checked under the dash, and found this:
The previous owner had removed a trailer brake controller. This must have been the wiring for it.
The red wire was tapped into a black/red wire on the brake pedal switch:
I though for sure this was the problem - a hot wire with an exposed end occasionally making contact with ground. I taped up the exposed ends, and the tap, and drove home.
But after about 20 minutes, another 'pop' and a visible spark from under the steering column, and the wipers and turn signals went out. I got home and checked fuse 6 - yup, blown again. I replaced it, and it immediately blew when I reached ignition position II. I even tried completely removing the wire tap and taping over the chink in the factory wire, but it's still blowing fuse 6.
What could I have done to short the wiper/turn signal circuit? Any ideas?
Fuse #6 is listed as Windshield Wiper Motor 20 amp.
https://sprinter-source.com/forum/showthread.php?t=24683
Did a wire get pinched to damage insulation?
Are all of the removed connectors back in proper places and completely seated?
Did a pin within a connector(s) get bent or otherwise damaged during the work?
bcman
That's certainly possible. my understanding is that most of the wiring for the turn signals and wipers is self-contained in Fuse Block 1. Any idea where I should look first for pinched wires?
I'm 99% confident they are.
That's also possible. I think I'm gonna check FB1 first, and also examine the relays there. I know one is for wipers and one is for turn signals.
The bus bars that form the connections behind/inside Fuse Block 1 are notorious for breaking free from their plastic "restraints".
Perhaps that's adding to the circus?
bcman
This morning I cracked open fuse block 1. Everything looked normal, although I have no frame of reference. But there were no loose pins or burn marks. I then got out the ohmmmeter to try to follow the flow of electrons through Fuse 6. I checked continuity with the left side blade for fuse 6 and each pin on connectors 2 through 5, and found it connects to pin 3 in connector 2. This matches up with the wiring diagram:
I then tested resistance between the black/violet wire at pin 2 and ground, and measured 2 ohms. Does this seem normal? I imagine this could be the resistance of the motor winding, and 2 ohms is ~7 Amps, not enough to blow a 20A fuse.
See the right-pointing arrow above the relay? That means that that circuit may go somewhere else, too (although they usually say where)
The black/violet is probably what powers the "park wiper" operation... if your blades are at the park position, i would think there would be infinite resistance between bk/vt and ground. (since the Home switch should be open)
bcman
Excellent, I was dreading tearing apart the dashboard again to look for the needle-in-a-haystack that is a potentially pinched & grounded wire. But this is enough of a clue to motivate me to get back at it. I'll report back in a couple days.
I agree with Vic that there could (now) be a bent pin in one of the many FB1/InstrumentPanel connectors...
(but that wiper ohm reading is really strange (if the blades are parked))
bcman
Found it!
it was wedged up against the metal part of the dashboard. when pulled away, it measures infinite resistance to ground.
Now I just have to cut, re-solder, heat shrink, wrap a few layers of electrical tape for good measure, and reassemble the dash (more carefully this time).
Thanks everyone for your help!
bcman
Hey Everyone,
I fixed the stripped wire, and re-assembly was a 99% success. Instruments, wipers, and turn signals all work as they did before the tear-down. The only differences are:
1. SRS light is on in the instrument panel
2. I ended up with 3 extra screws (the common T20 with captive washer) and these metal brackets:
I know they come from somewhere around the passenger airbag, but I couldn't find anything that looked right. The VA service manual and parts list are no help. Anyone have any guesses?
I wonder if the brackets act as some kind of ground for the airbag wiring, thus causing the SRS light. The wiring harness for the airbag has a symmetrical plug, so I tried it both ways, but the light is on either way.
During the work if any SRS component is disconnected (eg. - airbag) and the ignition key was cycled on the DTC will be triggered. Once it is triggered the SRS module proper must be accessed with a proper scan tool to clear the code(s). A general clearing of codes with a generic OBDII tool will not be enough.
Your SRS system may be ok now. It will require a proper reset or clearing of codes for the dash light to turn off.
