pointsunknown
Hi All -
I am having a problem I can't seem to fix on my espar D2 heater with easystart timer. The heater starts up and runs without a hitch. Then after about 5-6 hours of run time it turns itself off with the error "No Signal" displayed on the controller. I can turn the controller on and off and it maintains 'no signal'. But if I pull the fuse on the controller and then restart it it immediately starts up and will run again for 5-6 hours without a problem.
In previous winters, I was getting random errors when it was really cold and the heater was running on turbo mode for long periods of the time. It would kick off with error codes relating to fuel. I thought this might be in relation to my fuel intake routing or altitude so I changed the routing and installed the high altitude sensor into the mix (since the errors only happened when it was really cold outside and I was above 6,000 feet).
Since this fix I haven't gotten any more recorded errors, but I have repeatedly gotten the "No Signal" error. And it really is like clockwork after 5 or 6 hours of usage that it shuts itself down. Every night around 3 or 4 am when we are camping it turns off. I wake up with cold toes, reset the van power (essentially hard restarting the heater) and it turns right back on again and runs just fine till morning.
I've included a couple pictures of the wiring harnesses, for reference.
Thoughts?
Thoughts?
