I must be my own worst enemy
Dougflas
DAD OWNER
Changed transmission fluid, fiiter, and plate on the Sprinter today. Drained the torque converter even though I drained it 20K miles ago. The last time, I had a bear of a time getting the aluminum seal off the converter. This time I was prepared for it. I spent almost an hour on that. Then I saw the old seal stayed on the drain plug. So now I have a messed up sealing surface on the converter. I ended up putting a seal washer on it and torqueing it down. I hope it doesn't leak. If it does, I am going to have to address this surface.
Does anyone have a fix for this? Anyone know of a surfacing tool? I sure do not want to have to remove the tranny and converter.
And no one needs to tell me how careless I was. I am full aware of that and feel bad enough. I need new glasses I guess.:bash:
How badly damaged is the aluminum seal face? Little scratches or gouged out?
Off the top of pointy little head...
If the damage isn't severe the seal washer may just conform and seal.
To dress the aluminum surface I would suggest a proper diameter end mill cutter with just hand power. Another possibility would be a hand style DIY surface tool as outlined in the T1N injector thread. Some DIY ideas are buried in here.
https://sprinter-source.com/forum/showthread.php?t=16068
Don't panic and continue the personal adversarial relationship that you are concerned with. Maybe it will all just seal and be fine? :idunno: Periodic inspection should be easy by just removing the square plastic plugs for access. If it holds for a time it will be fine.
Bobnoxious
A&P Mechanic (RET)
Here's a photo of a counterbore and pilot. You would have to determine the correct size of pilot and counterbore and as Vic suggests rotate with hand.
misterbond10
then after you refurbish it, clean it all with brake parts cleaner and slather some black silicone RTV on the drain bolt to seal it better
Dougflas
DAD OWNER
Thank you Mr. Bob,
I forgot about counter bores. I have a set that I use for milling cap screw heads. I just measured one and it may work. So far, not leak but time will tell.
be safe
Dougflas
DAD OWNER
UPDATE
Still not leaking so I will say I am saved. The counter bore is a great idea. I found some from MSC that has various pilot sizes so I would be able to select a pilot and make a shield to fit around it so the threads do not get damaged. BTW the converter plug thread size is 10mm x1
UPDATE
Still not leaking so I will say I am saved. ...
Good news. :thumbup:
Not that you asked...
Resist the temptation to screw around for the next fluid change even if you have the new shiny tool in hand. You may create more problems than you cure.
Dougflas
DAD OWNER
That is my intention. No more torque converter drainings. I will just change the fluid more often. And BTW, the copper washer seal for the transmission drain pan is on national back order. have to try the Benz parts dept as I used my last one up.
Dougflas
DAD OWNER
Well it appears the plug is seeping. I ordered a counter bore with a 1/8 in piolt and a 10mm x 1 tap. I will fabricate a bushing for the pilot made of brass or aluminum so I do not damage the threads. I also ordered a 10mm x 1 tap to clean out the threads if needed.
does anyone know the capacity of the converter as I only have 3 quarts of Shell 134 fluid left.
thanks
thanks
As long as the newer drained fluid is kept clean, why not just re-use it?
For my peace of mind I always run it through a paint strainer funnel. That said, logic tells me that any stuff big enough for the paint funnel to catch would be caught by the transmission filter anyway. The fluid is introduced into the sump, so all of it passes through the filter.
Bobnoxious
A&P Mechanic (RET)
The other day I was thinking about your TC drain plug and the term I was trying to think of popped in my head. Spot facing was the term I was trying to think of. More of a technique than the name of a tool I believe. Sometimes, have heard counterbores called spot facers. I am assuming your intent is to dress the seaing surface common to the drain plug seal? A few suggestions if I may. Go slow and maybe practice on scrap trying to get feel for the tool. Sometimes, brand-new sharp counterbores have a tendency to chatter when using a drill motor freehand. Maybe attach the counterbore to a tap holder or wooden file handle. Doesn't sound like you have to make too many revolutions to dress the surface? Anyway, just brainstorming some ideas.
Dougflas
DAD OWNER
The other day I was thinking about er your TC drain plug and the term I was trying to think of popped in my head. Spot facing was the term I was trying to think of. I am assuming your intent is to dress the seaing surface common to the drain plug seal? A few suggestions if I may. Go slow and maybe practice on scrap trying to get feel for the tool. Sometimes, brand-new sharp counterbores have a tendency to chatter when using a drill motor freehand. Maybe attach the counterbore to tap holder wooden file handle. Doesn't sound like you have to make too many revolutions to dress the surface? Anyway, just brainstorming some ideas.
Thanks for the suggestions. I will certainly play with the tool first. and you're correct...it should not take much to surface the sealing surface.
Dougflas
DAD OWNER
Thanks for the suggestion. I will see how clean I can keep the fluid. I have 3 1/2 quarts left. I did find a Shell distributor 25 miles away. A case of Shell 134 is $62.56 plus tax naturally.
Mike DZ
2016 View 24V (2015 3500)
Amazon Shell ATF 134 Mercedes Benz Transmission Fluid, MB 236.14 and 236.12 - 6 Count (1 QT./946 ml. each) $45.76 & FREE Shipping
Dougflas
DAD OWNER
Well, here is how it went. I ended up using a 9/16 counter bore with a pilot sized to fit the threaded plug. I was able to remove the deep grove in the surface however the counter bore wanted to chatter somewhat. I can only hope this does it. From the picture you can see the groove that I was able to remove.
Bobnoxious
A&P Mechanic (RET)
Looks like an excellent job if you ask me. May I suggest a thin coat of RTV silicone to the sealing surface. And I mean a very small amount avoiding any "squeez-out" entering the tranny.
Dougflas
DAD OWNER
I put it back together with just a new sealing washer. I will have to se if it does the trick. I should have taken a photo after the machine work but forgot. Don from Silver Star Transmissions advised me a week ago not to use RTV. Also, Silver Star Transmissions were very helpful.
Dougflas
DAD OWNER
And my saga continues.... Looked underneath and saw some dripping at the front of the bell housing. I spoke with Permatex and they suggested using high temp thread sealant #59214.
Went and bought some today. Instructions state 72 hours for full cure. Permatex rep said that is for 10000 psi. He said give it 24 hrs if I could which is no problem. I can apply the thread sealant and turn the converter so fluid does not get on the plug. I inspected the drain plug and it was dry. A possibility is fluid is coated inside bell housing. Since I'm there anyway, I pulled the plug. I did not see any fluid on it nor the sealing washer. I read a post here that someone stated that the hole had a chamfer inside. My boring countersink did not leave that. I am considering touching it with a countersink/deburring tool in a drill. The sealing washer did show the imperfections the counter bore left.
I also read a post that DR.A stated that the front facing plugs on the late 2006's had a thread sealant on them.
What are the thoughts to touch the hole with a counter sink?
Since you asked...
Keep additional cutting tools at bay for a bit.
You stated the refaced/repaired plug was dry.
As you mentioned, there was fluid being flung all around during the previous leak. What is dripping may just be residual from the previous fluid.
Your transmission will not run dry as long as you monitor the leaking properly. Be careful that you don't overreact and end up needing a new TC as a cure.
Bobnoxious
A&P Mechanic (RET)
I concure with Vic, it may be residual fluid. Take some engine cleaner flush the area. If the fluid remains it Will accumulate dirt and become a baked-on mess. As far as using a counter-sink to debur and accommodate the shoulder of the drain plug? Ever so slightly. Again, countersinks or "rosebuds" as they are referred to at the tool crib, are prone to chatter when sharp especially on aluminum. I would take a brand-new one and use it a few times on scrap cres steel aka stainless to dull it a bit then it would be good for aluminum (your situation may very). As far as thread sealant is concerned, I would use a very very little. Just my two cents.
