MIL DTC Light Trouble Code DRB OBD List Info
There have been many questions related to Diagnostic Trouble Codes (DTC), but I didn't find a central location for the information. I have compiled some of the information I found on Sprinter-Source that I feel will help. I have also attached some Text Format (txt) document lists figuring that then people can access the info without needing Adobe Acrobat. I'm hoping maybe with an Ipod Touch over WIFI? I guess this belongs here in "Database". Hope this helps. vic
NOTE: Dodge and Freightliner dealers use specific scan tools for the Sprinter. An OBDII (On Board Diagnostics) scan tool may retrieve codes, but the Sprinter diesel engines are not required to be totally OBDII compliant. The Scangauge II will read more codes than some generic scan tools, but I believe it is still based upon OBDII specs.
Some information which may also help.
DRBIII, DAD and some other acronyms which may come up
https://sprinter-source.com/forums/showthread.php?t=50067
Places like Auto Zone, Advance Auto often will read codes for free using an OBDII scan tool. Unless you're using a dealer type scan tool use caution interpreting the codes that are indicated as there may be errors.
A comment from my scan tool manufacturer can be found here:
This is the answer from Actron
https://sprinter-source.com/forums/sho...5&postcount=10
Edit 2010/2/6
Dodge dealers use a DRBIII with a special adapter cable and card to access T1N Sprinter malfunction (trouble) codes and much other information. As of this edit, Doktor A (Andy Bittenbinder) can also provide a DAD unit which accesses much more information than a OBDII scanner does. The DAD may show codes which are not found on these lists.
DRBIII scan tools are not appropriate for ChandlerAZMan's NCV3.
The appropriate tools are: StarSCAN (end of life'd), StarMOBILE (dead man walking), WiTECH (current Chrysler corporate preference), or an MB Star Diagnosis System (MB SDS). -Jon
20100419 edit:
A comment by JD Caples about ScangaugeII and dealer code recognition.
Just so you know: The ScanGauge will report different integers for DTCs from the factory tool (Chrysler's StarMOBILE, Chrysler's WiTECH and MB's Star Diagnosis System (SDS)). So you can't go waving the numbers at any service advisor with an expectation they'll "jump to it." I'm not saying the Scanguage is useless, but the ScanGuage's ability - to come up with the same info that a factory tool will present - is limited. -Jon
Thread is here post #7:
Loss of power
https://sprinter-source.com/forums/showthread.php?t=10853
Caution: There are some inconsistencies or duplicate definitions for codes in these lists so care should be taken with interpreting the information. I have tried to update those problems which have surfaced in added posts. You will find them near the end of this thread.
Here's a quick link which has a nice scroll feature. I don't know how complete or accurate the list is. It's probably worth checking before using Ctrl F to search my listings.
http://www.fcrosby.com/sprinter/dtc.html
A txt link list of DTC related code posts and lists:
View attachment DTC_Codes_Misc_LinksTXT.txt
A SprinterDTC_P_CodeList_1 in txt format
View attachment SprinterDTC_P_CodeList_1TXT.txt
A Powertrain_DTC-1Codes list in txt format
View attachment Powertrain_DTC-1CodesTXT.txt
A DieselGenericOBDCodesPartialList in txt format
View attachment DieselGenericOBDCodesPartialListTXT.txt
Related links in Sprinter-Source
https://sprinter-source.com/forums/showthread.php?t=3799
https://sprinter-source.com/forums/showthread.php?t=5038
https://sprinter-source.com/forums/showthread.php?p=42243
https://sprinter-source.com/forums/showthread.php?t=833
I may try and add further posts with the actual text of the lists, but that may get too cumbersome.
2010/03/13 edit: Sikwan posted this info previously in another post. Thanks goes to Sikwan..
http://www.obdii.com/dtcanatomy.html
Some NCV3 Code Information (Moved up from Post #24)
I somehow had missed this NCV3 specific information related to codes. Thanks goes to JDCaples (Jon) for yet another great contribution.
Most, Maybe All NAFTA NCV3 2007 DTCs
https://sprinter-source.com/forums/showthread.php?t=7614
Edit 2010/2/6
20100419 edit:
Loss of power
