Just starting to add some acoustic insulation to the crew van. I pulled the OEM interior panels to look at where I wanted to add Noico sound deadening mat and was surprised to see the extent of what appears to be the factory thermal insulation is a 1/4" of closed cell foam on about 40% of the panel surface area. This package also included the passenger heat duct that runs between driver and passenger seats on the floor.
For what it's worth, the rear area heat duct is marginal to useless for pushing warm air to the bench seat but it's the only factory option for rear heat. The factory insulation is probably graded along the same lines. If I was going to order this van again I would try to break out the individual items (rear heat duct and rear insulation) and only order the heat duct. Not because it does very much but it's a little better than nothing. The two panel vents on the dash push much more heat to the rear.
I am pretty sure I am going to tear out the OEM foam and add damping material instead. I can't see the OEM material being much use for either thermal or acoustic insulation.
Hope this helps someone picking options for their crew van.
Scott
Scott
