I know this is a common problem. I've read through a few threads and got the impression that the usual culprit is the starter solenoid.
From what I understand, the dealers cannot order just the solenoid -- they can only get the complete starter/solenoid assembly -- but the solenoid is available on eBay and elsewhere.
Currently, the problem is intermittent but it is happening more frequently.
When the key is turned to 'start' I usually hear what sounds like a rely picking/energizing but the starter does not engage. It sounds like the relay is under the dash.
The relay seems to be on a timer -- once it picks, continuing to cycle the ignition switch has no obvious effect. Once it drops out, then turning the key to 'start' will cause it to pick again.
The chassis battery is good. It is on a Battery Tender and when the starter circuit works properly the engine cranks over normally and fires right up. Initial voltage drop on the ScanGauge II (while glow plugs are operating) is normal.
Any troubleshooting suggestions will be appreciated. I'd like to confirm that the solenoid is faulty before ordering one.
I wish the solenoid could be taken apart because it might be an easy fix, but I gather they are 'disposable'. That's too bad.
