First let me extend you a hale and hearty welcome to the forum.First post on Sprinter Source, so hello everyone!
I do have access to a DAD, I'm not sure if it is capable of the same ABS function as the DRBIII
Jake
It flushes the system. I had two people. I don't remember the entire procedure....
Vic, does the DAD process completely flush the system? Do you still need two people? I suspect the process is fully documented in the service manual? Inquiring minds....
https://sprinter-source.com/forums/showthread.php?p=93191#post93191Please look under 'manual component activation' for brake bleeding.
The ABS pump test feature you reference is under ABS test and calibration. Doktor A
Clicking the arrow after the quote name will take you to the quoted posting. vicAndy,
I've never been able to get the DAD ABS bleed program to operate. I've always gotten the "does not communicate" error. This is strange as I can communicate with the ABS module to check for faults.
Even though you say I don't have ESP, I have been able to operate the DAD ESP bleed mode 3 times. Once earlier this year, and the other times this week while trying to get the bleed procedure down. Two of the times while the ESP bleed was functional I terminated the program after verifying noise coming from the actuators. The third time I proceeded to activate the second wheel (after the first wheel was done). While activating the second wheel I got the "does not communicate" message again.
I tried different scenarios to get the bleed to work. Once I pumped the brake pedal while activating the ESP bleed function. I was pumping the brake before the "does not communicate" error appeared. This created a bunch of error codes that required multiple scans and ignition ON/OFF sequences to clear:
CDI Diesel: P2209: CAN commu. error with ESP/ABS control unit.
Instru. Cluster: B1041: CAN commu. error with traction control unit.
CDI Diesel: P2333: Vehicle speed cruise control: wheel speed
Transmission: P2310 CAN commu. with traction
ABS/ASR: C1000: Traction system control unit
ESM: P1876: The wheel rpm from the ESP system are not available on CAN bus.
I guess it's up to other DAD users to verify if ABS bleed works for them. As I mentioned before, you don't have to do a bleed operation to to check for DAD bleed functionality. You should get a foot massage when pumping the brake pedal to verify correct bleed/actuator operation. I hope someone can get it working and I find out what I'm doing wrong. My wife just reminded me that one of my main objectives in purchasing the DAD was to flush the brakes.
Cal
Doktor A supplied the DAD units. Contact him.Do you guys know where I can get ahold of a new DAD install disk? ...
The DAD is Doktor A DiagnosticsWhat specifically does DAD stand for? Not my Dad, cause he's of no use here....
If you can believe this...Oh yeah, DRB too....
Dirty Rotten Bastard?
^^^ that's what it means according to internetslang.com...
