pretty simple,drivers side radiator has a valve down low,you can see it from the top of engine bay with a flashlight,on the side of the valve there will be a little hose spout,i used a 5/16 inch piece of fuel line to connect to hose spout long enough to reach the ground with a oil pan drain container,turn valve aprox half a turn and it will drain about a gal out
