I'm not sure what vehicle the OP owns but since the chart was for an NCV3 V6 then I will assume that's what he has. If so, as I clearly pointed out the V6 electrical system maintains approx. 14.1 volts (and that is indeed what I measure at my house battery bank while the engine is running) and that is quite adequate to push more than enough current (60+ amps isn't enough?) thorough the batteries. and while 14.1 is a little low for an absorption charge rate it is plenty sufficient to fully charge a FLA battery. It is indeed not an ideal charge regimen so a full 3-stage charge should be applied when stopped and connected to shore power (which is why anyone should replace the OEM converter with a proper charger), but in-between times the vehicular electrical system (at least with the NCV3 V6) can indeed provide an adequate (if not ideal) charge cycle. Countless RVs operate this way with good results. If you are never able connect to shore power and thus apply a good soaking absorption charge then you should probably have an alternative, but that is not typical in most cases.Just to be clear, in a battery charging system, voltage is king. The current data is very unimpressive when alt voltage is 13.7 to 14.0V (your normal situation). You need higher voltage to push current through the batteries.
Don't recall what battery you're charging, but my house batteries want to see 14.8V. They will not get fully charged when charging at 14.0V.
You might be able to charge to 80% soc with your alt. I would not call that a viable option.
The above is in reference to a V6. If a T1N can only supply 13 volts as you noted earlier in the thread then that is a different story, although I have to say I'm surprised if the T1N electrical system is really that deficient. Can't say though as I've never owned one.
