Who does T1N ECU testing.
Isla
I've come to a dead end on several different issues I'm having with my sprinter. I'm looking now at getting the ECU tested and can't find much to go on. Who does this and roughly what does it cost to get an ECU tested? Thanks!
Sent from the first city on the Mississippi.
Isla
Gde does? I just bought a tune from them. Thanks for the info
I really don't know if they *test* the ECUs (as a specific service), they're just the only two vendors mentioned here who do *anything* to/with the ECUs.
(people have sent in ECUs to GDE, had them return "working", but never heard what (if anything) was wrong with the ECU when it arrived in GDE's hands).
I would suspect that GDE rewrites the ECU *first*, and then does whatever tests they do. That's simply the more efficient way to crank them through...
If the ECU tests as "bad" after-the-rewrite, then it becomes "diagnostic time".
Just give them a call (or email) (and please report back with results...)
good luck
Isla
Keith at GDE said he doesn't do any testing or fixing. He said id have to find a Bosch facility to do it. He also said if the ecu has any problems the truck won't start.. Which I don't believe is true based on my research.
