jmoller99
Own a DAD ODB2 Unit.
The plastic dash vent louver pieces pop up too easily and I seem to break off one (or both) of the tabs, so I can't get them back in.
Here is how I fix it once I've broken off a tab (in this case 2 of them - one on each end).
I ordered some 10mm long watch band spring units (on eBay, with free shipping, that amounted to 99 cents). These are 1.5 mm in diameter (1/16 of an inch drill bit is slightly wider, so it works).
I drill out approx 8 mm deep into the plastic louver on the side that I'll ease into place (so it only sticks out as far as I can compress it all the way). The other side sticks out further (I put that end into the assembly first), so I don't drill it out that deep. If you are only replacing the one tab, its simpler.
I used a short length of metal coat hanger to get behind the snap on so I could pull the louver snap on piece together and then slide reattach the louver (like you do with a watch band).
I was never fond of how this part goes together (it's too easy for it to come apart during disassembly and reassembly). I have 3 louvers repaired in this way on my dashboard. I recently had this one pop out, so I captured a few photos of how I addressed it
