Doesn't that success depend upon the puppy?... now its puppy proof.
Ok. It will take me a week or two but I will get the pics of what I need.I can depending on what you need, might have a few left from last run
word, Carbon is a 1yr Malinois, So I feel pretty confident that they are a bit strongerDoesn't that success depend upon the puppy?
I wish I knew how many ppl need this linkage, I have to use a different manufacturing process thus investment on my part to supply. Comments welcomeUpDate 4/17/022: for those with no vents component's at all, I am in process of fine tuning the vertical linkage bar (this part allows all flaps to move as one) once I am happy with the part and manufacturing process you will be able to fully restore vent flappers, and action as designed but at a much more robust level structurally. FOOTPROOF & FOOLPROOF DM for Info
I dont have the brain power to figure out the "drop in assembly", have been kicking it around. Thus why I did the next best thing Binford style lovers/flaps. they really are far superior to the all plastic originals, if every other one was replaced the vent could take a impact and keep on flappingSo far I only have a few busted louvers, but have seen some vents needing the whole assembly, as you’re building. Seem one item that is needed is a drop in Lou er replacement for vents that have most/all Lou era missing.
Good luck with that, have scratched my head abt that, let me know what you come up with. KurtI was thinking about printing the Globr/Orb type directional nozzle, it would flow better and be somewhat easy to do.
Probably have to send it out for SLA to take the heat though....
What are you making parts with? I've had good luck with Prusa Polycarbonate Blend on high heat locations. Knobs for our gas grill are great where PETG softened up. It's at the upper limit of what my Prusa Mini can do before the hot end PTFE tube shrinks and needs to be replaced.Good luck with that, have scratched my head abt that, let me know what you come up with. Kurt
We used petg for some initial stuff, then shopped the production out to a SLA printer in N.Phx.What are you making parts with? I've had good luck with Prusa Polycarbonate Blend on high heat locations. Knobs for our gas grill are great where PETG softened up. It's at the upper limit of what my Prusa Mini can do before the hot end PTFE tube shrinks and needs to be replaced.
Regards,
Mark
There are some high temperature SLA Resins and you can get shapes out of SLA that are challanging with FDM printing. So, if you already have that set up, I agree it is probably the best way to go. I have a copy of Soldworks, but am not expert in it. I am much more familiar with OpenSCAD. Others would have to determine if I've reached "guru" status.We used petg for some initial stuff, then shopped the production out to a SLA printer in N.Phx.
I haven't used the printer that much and rely on a friend who is a "Solidworks" guru to do the modeling...
When he is done with a current project I will sit down with him and do the modeling. it will take less than an hour.....
Email me a Photo of your vents I can see if I have a solutionI need vents ! Are you making 3d ?
