Fixing a broken plastic dash vent louver
... plus I think at least one of the holes that the pins of the louvers go into on one side is broken out, so even with a pin repair of louver I would still have an issue on at least one.
I have one louver with the bottom of the hole broken out. My plan is to attempt a repair using the super glue and baking soda trick. I'm going to use a toothpick to apply some Vaseline on the pin as release compound. The trick will be to not get so much Vaseline around that it interferes with the repair bond.
Kbonk
This passenger side OEM part found here, can be bought below for https://www.ebay.com/itm/NEW-MERCED...344746&hash=item523db4f27c:g:r4sAAOSwWVxezlGK. for $117.05 here https://www.ecstuning.com/b-genuine-mercedes-benz-parts/covering/9016801607/
This is still the Shelf version and not the passenger airbag version so I guess that is not available anywhere and the removal of vent only as Kbonk did and moving it to the old airbag version and retrofitting is the only way to remedy this issue?
I almost have the right side done, first prints look great. Trying to source a spray bomb color to match OEM plastic now. Depending on how much of your pin retainer got blown out it shouldn't matter the pin retainers have alot of extra room behind them. (the louver is what retains the pin right to left) I would say extending the pin on the blown out one will resolve your problem.
Kbonk
Vic, a ABS slurry can be made from sanding or filing of ABS and Acetone. Silicon jacketed wire might be perfect for your in fill of the void. I also had the blow out on some of mine. Since the factory louver pins are so short I just extended the pin on that side, the rear clam shell held the louver centered. I will try to get your set out this week.
I would not give a heck about color matching, if I could acquire a drop in air vent louver, for the vent closest to the passenger side window, but that is just me.
Thanks for whatever progress you have made Kbonk.
A couple of my broken louvers are resting down the vent hole. I have no illusions that they can be recovered. Gravity works. 06 2500 T1N.
Kbonk
did you try using a vacuum, with a stocking over it to suck them out? I just finished the left set, DM me with your requirements.
Dr. No
Does anyone know of a source for the valve behind the louvers? Or at least the connecting crank between the wheel and the flap?
ECU
That is all 'one part' to Mercedes.
Dr. No
Nope. It is not part of the louver/vent surround/dashboard. It is the control valve for the vent and goes between the louvers and the duct.
I found my own answer (took more time to find the right name). Each of the four is a different part but you can find them from here:
Apparently "outlet air" is the appropriate name. Not "control flap" or all the other things we call them. And they are strangely cheap!
ECU
If you want louvers, why would you rip them all out?
bored
Digging up an old thread....
@Kbonk are you selling replacement vent louvers?
