Yob2kanobe
2017 Unity U24MB LL+
Never deployed, Im leaving my carefree awning on just for the LED lights!
I had same issue of the awning would not extend only about 8 inches and then hang up on the housing as the folded extending arm was coming out. ( Extending arm closest to the front of the van ). I added several pieces of felt material inside the case where the folding leg rests in the stored position, and that has helped the extending arm slid up and out of the storage cavity.Originally I wasn't going to bother to post my problem I had with the Carefree awning on my 2016 Unity IB but after spending hours resolving the problem the second time around I figured let sit down with the iPad and a cold beer and tell my story. The story starts last year upon taking delivery. Purchased the unit from Wagon Trail here in Vegas, no complaints with them, matter of fact they have been wonderful. Also one of the best built units I have ever owned.
The first time I used the awning the aft arm would hang up on the housing when extending. So after the shake down cruise back to the dealer it went. Adjustments were made in the shop then the rig was brought out front to demonstrate and guess what, it hung up. A quick tweek on the rear arm and all is fine. Until the 2nd time I went to extend it, same problem. This time I'm tackling the job myself. First adjustment was made by loosening the mount (1 bolt) and moving it forward approximately 1/8". That helped but not fully, I ended up replacing both of the M8 button screws with slightly longer bolts to raise both arms up a little. That solved everything, I hope. But I also noticed that both of the black plastic "latches", one on each end, that lock the awning to its housing were loose. Some blue thread locker on the treads should solve this issue.
Shouldn’t the support arms retract without any help?I too have had the awning on our 2014TB malfunction. However; your problems seem more involved. Our awning would not extend unless I repeatedly worked the switch or manually assisted the awning to extend. I found our problem was that I was not positioning the support arms far enough into the storage sleeve when retracting the awning. If not pushed far enough into the sleeve the end of the support arm would bind in the end cap. Since I now push the arm in at least 6" I have had no problems.
Sandy,What a great solution! Using the awning manually is a great option. I always hate having to open the passenger door to operate the switch anyway. It lets the air conditioner cool air out and the bugs in. I have a 2014 UMB but I hardly ever use my awning so if I do encounter motor problems I certainly will go this route. Thanks for the installation details and part #s, but could I ask how much the 3 parts cost direct from Carefree?
Ditto on the issues, adjustments and multiple emails with Cory Klenk at Carefree. The one thing I found was that the top side of the awning was actually sticky. Cleaning and scrubbing with soap and water eliminated about 90% of the hesitation and need for poking the housing to get the awning to extend. And those under-designed orange flippers? They sent me a couple spares to get me to quiet down.The awning on our Unity seems to bind up when opening and retracting. The motor continues to turn but the awning stops moving. With some assistance on my part, I can get the awning moving again.
Has anyone had similar issues?
It is a Carefree brand awning.
Any info will be appreciated.
Sandy,
Here are the prices from the invoice. Figure $15-$20 for shipping (UPS GND)
R001619GRY Freedom Wall Mount - Gear Assembly, Manual Crank $137.36
R001546-RP Freedom Wall Mount - Telescoping Crank $61.60
R001622 Freedom Wall Mount - Roller Tube Endplug, LH $15.86
Note: Any Awning crank with the oddly shaped hook at the end; and, that is relatively short will work. In hindsight I would have purchased a crank another source to save a few bucks.
Sandy,
Two parts (the wand and the gear assembly) shipped immediately. The third part (the spacer) was on back order for two months. Give them a call and see what their shipping times are today.Sawdoff,
What was the shipping time? (Looks like my motor has failed.)
—Larry
YES ! Hand cranking the awning in and out is easy and reliable. Typically takes me 12-15 seconds. The best part of the modification is that the operator can "feel" through his hands how the awning is moving; and if there is any binding or sticking, stop the process and clear the problem. No more guessing why that frigin' motor is sitting there and just churning !!!Sawdoff, are you happy with the manual operation?
No complaints?
My motor is bad, according to Cory, I think I may try your fix. Probably more difficult to install the motor then change to manual.
harry salit
