Passenger air bak vent assembly removal?
TooFast
TooFast
Passenger air bag vent assembly removal?
I've searched without any luck....
I'm replacing the passenger side crescent moon shaped vent assembly due to both vents being busted and parts missing.
First I will disconnect the battery for air bag purposes,
then whats the easiest way to remove the vent assembly - the new one has places for two screws on top and snaps on the bottom.........
Thanks for any help
sikwan
06 T1N Can
Pull up the leading edge (forward side) of the crescent shaped dash top. It should just pop up, slide forward and away. Once it's out, you can probably figure out how to remove the other stuff.
TooFast
TooFast
Re: Passenger air bag vent assembly removal?
The new vent assembly has two screw slots > < left and right orientation on top that I was thinking might have screws in them. I'll try your lift and pull - and stop if I feel like there are screws holding it - Thanks Sikwan
