carcrusher
Hi All,
Just purchased a 3500 Tuesday and on the drive home the resonator split open. Looking on Amazon/Ebatty and the kit was $129.00. Seemed like a lot of cash for a short length of 2" sch. 40 aluminum pipe...........and it was days away with shipping from states away, Sooooooo.........here goes my MacGyver episode. I used to fabricate race cars in a past life.
I cut the tube to 5". At the tablesaw, I put a 1/16" deep kerf (notch) all the way around the tube about 2 blade widths wide and 2 blade widths into the tube.
I cut a 1" x 1/4" strap the same length as the factory arm and took them to the welding table.
Using the OEM resonator to mock up some jigs I noticed the arm was set at 45 degrees from the tube. Whew...........thought this would take a few trys, but I nailed it first time. It was easier than I thought. The 45 degree offset was easy to jig up. Sand the finished edges with 220 for a smooth, no-sharp-edges finish on the tube ends.
The factory O-ring will not work, too thick, go obtain a 4mm x 44mm from the auto parts store and fit the tube in the turbo with some assembly lube. Scribe the hole locations in the arm as it sits against the factory bracket and drill them 1/4" Dia.
While at the parts store get some 6mm bolts to replace those PIA factory things.
Bolt it on and enjoy the $$$ you saved. I know this is a little more than the average NV1 owner might try to do, but it wasn't that hard (nowhere as hard as I thought it would be).
country boy can survive..............
