PortlandRV
2012 and 2016 IB
Has anybody had any issues with a very annoying squeaking noise coming from the side entry door while driving? We have the keyless entry on our 2016 IB and the squeak has gotten worse and worse over time.
I think it might be caused by too much play between the door and the door jamb. I can see this by pushing on the door inward from the outside when it's closed. In doing so I hear the squeaking sound. I thought this could be corrected by moving the striker plate/latch inward. But the service tech at Johnson RV tells me that the door won't close when they moved the latch 1/16".
I went around the lot and pushed the doors on the other new Unitys at Johnson RV and they did not have the movement in the door like mine does.
Here is the response from Johnson RV:
We adjusted the striker plate/latch inward 1/16”. Once we did this; we could not open or close the door. We moved it forward very slightly to rectify that issue; and the door opens and closes without squeaking. This is the best we can do with the current door/latch assembly. If the issue persists; the next step would be replacing the door assembly. Replacement would not guarantee the problem wouldn’t occur again.
Very frustrating
Very frustrating
