My 2011 Sprinter-based motorhome (MB3500, 38000 miles) won't start. I had moved it a few yards in the drive way to clean leaves off. It had started up ok, did seem not to run at its best (had it used a few days before without problems). When I wanted to move it back after a few hours, it won't start. That is it even does not crank. Headlights are full there and even do not dim when turning the key. Gear lever is in Park, even wiggled it while turning the key. The ScanGauge does not show any codes. I charged the battery in the vehicle overnight, no change. I attempted to jump start, nothing. I took the battery out and had it tested and it was determined to be in good condition.
Any suggestions are much welcomed, nearest MB dealer is 50 miles away.
