'03 3500 left rear directional inop
jgventura
My LR taillight directional/hazard is currently inop. My left headlight, left fender, and left trailer directionals all work. Taillight light circuit board assembly is brand new, no change. I tried looking at the diagram in STAR but it's quite confusing. Suspect broken wire but the harness just disappears up that rear pillar. Any ideas? THANKS!
NelsonSprinter
Former Nelson BC Sprinter
I suspect a burnt fuse, you may have to test them all with an Ohmmeter under seat & under steering column
You can download the full 2003 service manual from http://aie-services-2.net/Sprinter/
The parts manuals are also handy, since they give a sense of what the long cable runs look like and where they go.
The tail light schematics are in section 8w-51
How the cables are run is on page 8w-91-32
Some of the bulbs share the same wire with the right side (brakes and backup lights). If they also don't work, then suspect a broken ground (brown wire).
good luck
