RockyRaccoon777
2020 144" 4x4
Okay thanks - glad I asked! So the obvious next question what’s the recommendationded sealant for that purpose?
I've just been using an RV sealant like Dicor, gobs of it,Okay thanks - glad I asked! So the obvious next question what’s the recommendationded sealant for that purpose?
As mentioned previously, that rubber is not UV nor weather resistant. It will not last very long.I used rubber seal from 80/20 catalog #2115. I found on YouTube by Humble Road guy. It is cheap and you don’t need removing moulding.
A tube of Dicor sealant to use on the clips is $10......It coast like $0.50 a foot + shipping. Even if last a season it is fine with me.
I tried twice to get that stuff inserted. Couldn't. Maybe I wasn't persistent enough, but I sold it locally. Hope you have better luck.It coast like $0.50 a foot + shipping. Even if last a season it is fine with me.
How much did you find it for at your local dealership? I posted somewhere that my local dealership sold it for something ridiculous like $4, and I bought a couple. I ended up buying a bunch of cheaper oem ones. If anyone needs some, just let me know. I have a bunch of spares.I can confirm the VS30 clips work great on NCV3. The clip is a bit different snd much easier to install and remove from the door panel. The orings have a good, tight seal on the door. Light taps is all it took to install the panel (with clips in it) back onto the door. Took serious hammering with the old clips.
Would folks still advise putting sealant around the newer clips?I can confirm the VS30 clips work great on NCV3. The clip is a bit different snd much easier to install and remove from the door panel. The orings have a good, tight seal on the door. Light taps is all it took to install the panel (with clips in it) back onto the door. Took serious hammering with the old clips.
