Engineer In Residence
I cut the drain hole. I just got some sikaflex adhesive, so the pan should be getting bonded in tomorrow. Once its bonded in, I will sand the edges flush with the floor, and seal the gap with some urethane. I will cut down the removed floor section to a tight fit, then use some rigid foam and wood spacers to bring it to normal height. There will be a small seam, but when I replace the floor covering, I can minimize it. I may try to fit some latches, but given its light weight, It may not need it.
Jen cut some access doors in the back of the bench seat. These will give us easy access to the storage behind the seat. She also reinforced the seat back with some steel bracing.
