Sutherngintelmen
Curious as to your 'complexity' comments on lithium battery (cost at $2k + for 200ah is pretty clear!) as I'm researching similar set up - can you please elaborate on additional impacts to your set up - agm vs lion?
Here is the final electrical to be implemented mostly by this weekend. I did not show all the grounds on the loads or all the lighting circuits.[/QUOTE said:Regarding your final electrical install; would it be possible to run that OEM aux battery in parallel with your other 12v batteries to increase the AHs? Or, perhaps they're too far away? Some #4/0 (0000) wire could take care of the distance problem perhaps? I'm still a newbie with electrical and I'm more curious than anything. According to http://circuitwizard.bluesea.com/ you could run AWG2 up to 15 feet at 150amps.
Also, I noticed your concern about skis getting water in the vehicle and wanting a water proof 'bin' of sorts. I have a compartment that is for bikes in the late spring - fall, and skis in the winter. I've had problems with water collecting a couple times but only when I don't do a thorough job in getting all the snow off my gear after slaying POW all day. Personally I would separate where your skis are going to be in the 'garage', do a good job in getting the snow off, and not think about it too much since it's tucked away. At least that's my configuration and it's worked great.
Regarding Lithium complexity,Curious as to your 'complexity' comments on lithium battery (cost at $2k + for 200ah is pretty clear!) as I'm researching similar set up - can you please elaborate on additional impacts to your set up - agm vs lion?
Vanski,It's been a while since I've visited your thread... AWESOME!!!
If you have two 6v batteries they are have to be in series to obtain 12v and if you have 12v batteries they have to be ran in parallel.That makes sense. I currently have two 6v batts running in series and am thinking of adding two additional 6vs in the series, but I'm wondering if the difference in age would even impact the battery life. Thanks for the detail..
Ummmmmmmmm... Yes, that's why I said adding two additional 6vs in series to my config as an example of a series configuration. The Powder Assault Vehicle is being configured with 12v thus parallel.If you have two 6v batteries they are have to be in series to obtain 12v and if you have 12v batteries they have to be ran in parallel.
I just ordered 2 100Ah 12v batteries to install in parallel to make a 200Ah.
Jon
Sorry, I must be tired. I only mentioned because I got them mixed up when I was trying to order 2 12v batts to wire in series........They asked if I was doing a 24v system.Ummmmmmmmm... Yes, that's why I said adding two additional 6vs in series to my config as an example of a series configuration. The Powder Assault Vehicle is being configured with 12v thus parallel.![]()
If you have access from under van, drill up through the hole from underneath.Prep for structure attachment
I then triangulated the locations with string from various angles and marked the locations on the walls, so I can find the bolts later. I'll have to drill thru the OEM floor later.
Wow, that would be super useful for me if it was for a 144 WB. Were those holes exposed? Or did you find a drawing? Or how did you locate them......X-ray vision? Most are not visible from below on my van.Here is a layout of all the M10 threaded holes I found in our 2010 3500 170WB:
http://www.impact3d.com/2010MBSprinter3500_170WB_OEM_floor.pdf
Good idea but most threaded positions are not visible or are offset from holes in frame members from below. At least in my van....If you have access from under van, drill up through the hole from underneath.
I was referring to the new holes you are drilling.Good idea but most threaded positions are not visible or are offset from holes in frame members from below. At least in my van....
