Deancm
I have a NCV3 2500 3L V6 built June 2008. As preventive maintenance I replaced the infamous "Y" Cable. Attached are photos of the old cable and one of the newly installed cable.
1. Shows the 300 Amp fuse shrink wrap cut open. There is a serious design problem here. Note where my fingers are holding the shrink wrap open around the corrugated outer covering. This allows the corrugated covering to be channel for any water entering any break in this outer covering to flow down to the fuse which is the low point of the installation. The cable is just crimped and not soldered to the fuse.
2. Shows the 300 Amp fuse split open. The fuse is a narrowed part of the brass piece crimped around the cable at each end. It has plastic molded around it. But note, I am holding the part that goes in the center that says "300 A". This insert (which in the picture is split) is just clipped in, so it is not sealed. This allows water to corrode the fuse. Plus heat from current flow does not help.
3. The "Y" part of the cable split open looks good. It was soldered as well as crimped.
4. This is the tag for the old cable showing it was built May 22, 2008.
5. Here is the new cable installed. Note the heat shrink is over the cable and NOT the corrugated covering. BIG IMPROVEMENT!
