Some Bed Platform Support Ideas/Options
There have been some great ideas put forth as to how to provide support for a mattress. Some are very basic and others more complex as to being hinged, snap-in, clipped, etc.
Some of the threads are quite long and include many other details. This thread is intended to focus on various methods of wall attachment and platform supports. I'll start this off with my opinions. Please feel free to add other ideas.
Many discussions relate to number of fasteners. I've posted this as an example of shear strength.
This is my green side rail support.
I used salvaged aluminum temporary safety railing parts for the cross supports. Other possibilities include Unistrut Channel, EMT Electrical Conduit, pipe, 2 x 4's on the flat side, and most any other strong enough structural shape.
More details on my Loft Bed are here.
https://sprinter-source.com/forums/showthread.php?t=4827
The IKEA Skorva bed beams looked interesting so I did the Google.
SKORVA: Swëdish for "Go back to the store"
Skorva Beams look like they would work with the notched 2 x 4's and probably other types of side wall supports. My concept would be to cut the Skorva beam ends off by about 1" each (for better thickness) so they can be set upside down into the 2 x 4 notches. Double check for the application as to date I have never personally seen a Skorva beam. It looks very promising though.
A Fast Pin could be used to hold the slip adjustment to the correct length and still allow the beams to be collapsed/shortened for storage.
Quick Release Fast Pin
After further reflection I believe that this is a better design for securing IKEA Skorva side to side.
Alternatively a single screw into the 2x4 pocket on each end of the cut down length, upside down Skorva beam will hold position and eliminate the need for a keeper pin.
I recall one member who used 3/4" plywood without any cross supports. Doesn't get much simpler than that. I don't have the link for that method.
To hold my bed platform plywood into place I use 1/4 - 20 studs with washers and wing nuts on the four corners (studs screwed into the 2 x 4). For the center sections I just drilled 2 holes straddling a few aluminum cross supports and tie them onto the cross supports with heavy cord.
I used a simple notched 2 x 4 with aluminum cross supports. The cross supports nest into the notches unfastened. That allows them to float which almost entirely eliminates pullout stresses as the van body flexes.For practical application there's a big difference between a given structural shape uninstalled as opposed to fastened in place for use. Many structural shapes are flimsy and can be bent by hand, but once they are installed and in service that is no longer true.
2 average adults may typically weight 400 pounds total. 3 - 4 average adults is probably in the 600 - 750 pound range.
That's really not a bunch of weight when it is distributed over an entire bed platform. The weight is not point loading the structural members. It is distributed. A bed platform supported by any brand van walls will not stress the walls to the point of distorting them. The loads just are not that great.
As long as pullout stresses are minimized so the fasteners see mostly shear forces it doesn't take many fasteners to hold the structural shapes to the walls to properly support a bed.
I used this example in another thread as to what a relatively small pin can support.
A comment on shear strength of fasteners and the number needed for supporting a bed.
The cable backstay on my sailboat is held at the top by a single 3/16" pin. I feel this is a good example because it is easy to see that all the force is concentrated on this one pin.
This is the specs of the cable that is used.
1/8" SS Aircraft Cable
Breaking Strength:1760 lb
Diameter:1/8"
Finish:PlainGrade:304
Material:Stainless Steel
Specification:MIL-DTL-83420M
Strand Core:7 x 19
Type:Aircraft Cable
Work Load Limit:350 lbs.
As an aside, 1/8" galvanized steel aircraft cable has a Breaking Strength of 2000 lb and Working Load of 400 lb. The same size pin is used. Contrary to what some may think, ss is not generally stronger than plain steel. SS resists corrosion and may be harder.
http://machinedesign.com/materials/comparing-stainless-steel-and-other-metals
This is the pin shown relative to the size of a dime.
The pin is not the weak link as to the 1760 lb breaking strength above. I have seen rigging cables break as a result of collisions. The pins used in the cable assemblies are not a typical failure point.
So even if your fasteners aren't equal to the pin design/material in my example, it is easy to see that it won't take too many properly installed fasteners to support a couple people on a bed platform. This example relates to shear strength, not pullout. Pullout is another discussion.
I'm not saying that sleeping platforms/beds can be installed without some sort of thought as to stress and strength of materials. What I am saying is that installing a proper bed platform is not necessarily rocket science either.
I made the frame with ikea skorva beams which are cool because they are telescoping/adjustable, and $10. You'll have to ask the "as is" dept for some skorva mounting plates because those usually just come with the beds.
https://www.flickr.com/photos/optikalblitz/3232592916/We assembled the bed from head to foot. It looked beautiful......then came this phantom "midbeam" the directions pictured. Alas, it was in none of the boxes that were required for us to build the bed. A phonecall later and a couple "wtf" moments later, it was decided:
1. No, i will not elect to pay 78 dollars for a 10 dollar part to be shipped to me within 3 days.
2. Yes, i will be driving back to Atlanta to walk in the store and pick it up myself.
I might as well add my E-track method to this thread. It is installed in my 2006 passenger van, but would work for cargo models also.
E-track Rear Deck Bed Support
https://sprinter-source.com/forums/showthread.php?t=52227
