Hello all, I have 2006 dodge sprinter 3500 with 59,000 miles im 1st owner, Just had new trans installed at local trans shop, apparently the tork converter imploded and took the rest of the trans with it, also had oil change, fuel filter and serpinten belt changed, he was highly recommended and works on whole fleet of fedex sprinters, picked truck up Thursday, drove home 16 miles great no problems, Saturday morning I come out to start the process of restocking the truck stated right up, though I heard an unusually knocking sound (was not sure if it was low on oil or just because it was 7 degrees out, took truck out of driveway brought to level parking spot to check oil, oil fine, but would not turn over, turned key coil light came on , coil when out but nothing no clicking like when battery is low, but he mentioned battery was not holding charge, so grabbed charger, put on charge tried again no good. called him up said try wiggling shifter, sure as **** it starts, ran truck around severl stars and stops no problems,
come out this morning truck turns over but not at a great pace but does not start sounds like it wans to but no joy, but not to the point where the lights in the dash flicker when the battery is really dead. but figured I would try to put it on the charger, noticed it was not taking a charge so replaced it with a new battery fully charged, and tried moving the shifter from park to nutrel and back. Same result, truck turned over but did not start, and stopped turning over with my hand still on key. Now when I try I get nothing, coil comes on and goes off, but not even a click of the starter, I checked all fuses and swapped out relays, checked to see ground was good, looked for any shorts but have not seen any. Have constant power coming to (3) terminal or the 30 on the wiring diagram, and when I turn key to second position I have power to the (1) terminal or the 86 on wiring. Where do I go from here?
Any help is greatly aPPRECIATED.
RIVISION
iM AN IDDIOT that was fuel pump relay, Have constant power to (1) or 86 when key is in 2nd position and power to (5) or 87 on turn of key on starter relAY
RIVISION
