Dave,
You may have a heating pad convert.
Next I am working on determining if a small insulated enclosure around the sleeping platform works. Have four double wall curtains that I installed Thinsulate between the two pieces of cloth in the winter and remove the insulation in the summer. Want to try and retain some of the body and heating pad heat inside the enclosure. Do not want to heat the entire van and do not want a noisy heater cycling on/off during the night.
The back curtain goes from top of sleeping platform up to the ceiling. The front curtain has three parts. The two side curtains go from top of bench seats to bottom of the upper cabinets. The front center curtain goes from the floor up to the ceiling. The center curtain is opened for entering and exiting.
Have used curtains one time and found four issues.
1. The back curtain sagged in the center so did not close off that end.
2. I only had a 1" overlap between the side curtains and the center curtain that was not enough to close the gaps.
3. The insulation in the front center curtain dropped to the bottom of the curtain.
4. There are two large openings between the front two panels when they are stored vertically that need to be plugged.
Even with those mistakes the enclosure does work. Outside temperature was 39 degrees, inside front section of van was 46 degrees and inside the tent was 54 degrees.
I am working on the mistakes.
1. Added a short piece of 3M dual-lock (velcro) to hold up center of back curtain.
2. Having Strawfoot remake the two side curtains to add 3" to the curtain width to make the overlap 4" instead of 1"
3. Added four magnets at top of the front center curtain to hold the insulation up.
4. Will plug the two gaps between the front panels and the van wall with 1" closed cell foam.
Will report the results after I get the new side curtains. Looks like it will be worth the effort.
I bought the Transit remote start and have a vehicle powered inverter that I can set to power a 750 watt electric heater with the engine running. One of the reasons for getting rid of the diesel Sprinter was to get a gas engine that can be idled. I push the remote start button before I get out of bed to warm the van interior in the morning. The gas engine is not any noisier than an Espar.
