Get the second battery option. We got a manual awning in place of the power one, and removed the TV sets but kept the tv prewire and antenna. Vent covers so you can leave the roof vents open in bad wearing are a nice option. Decide how much inverter power you need to help size the inverter. We got the smallest one available which was a 600 watt. For more than that we run the lp generator.
I would get the factory solar package as well.
Hi Chromisdesigns,
When you say "Get the second battery option" do you mean to get four 6 volt batteries instead of standard two 6 volts? With a solar panel option (160W for $1495 extra), wouldn't four batteries be an overkill? (or am I showing my ignorance). 160W with 12V (with loss) is less than 10 Amps (?). Or do the generator (propane or diesel) charge the batteries? (again I may be showing my ignorance) I suppose more batteries are better than less...particularly if shore power is not available.
What is the advantage of the manual awning versus a power one, excluding the price of power awning option at $2960? Less to go wrong I am sure, but how does one extend the manual awning? Even the manual awning is probably not free...how much did you save?
We plan on asking Coach House to remove the TV and blue ray player, but keep all the other peripherals such as wiring, antenna, speakers, etc. I think this is a good idea on your part.
The Platinum II comes with two Fantastic Fans with rain sensors. Are you suggesting to get another type of a fan or another type of a vent cover?
The standard inverter is rated at 1,000 W. Why did you option for 600 W inverter? Aren't higher rated inverters better than a lower rated one? (or am I showing my ignorance again?). If the two 6V batteries are rated at 220 amp hours and assuming 50% usage, 110 amp hours x 12 volts = 1,320 watts...is 1,000 watt inverter enough? As with solar panels and generators...this stuff is confusing.
Other than what you recommended, I plan on adding the following:
(1) Heating Pads for grey and black tanks
(2) Stabilizer Jacks (will increase GVW by approximately 85 lbs.)
(3) Wifi Amplifier
(4) Solar Panel (160W...probably only good as a "trickle charger.")
(5) Auto-starting generator switch (to save our two cats left in our van during our absence).
I am still debating whether nor not to order a diesel generator (weighs 27 lbs. more) in lieu of propane. Any thoughts on this?
Also, still debating on adding a macerator pump. The wife wants it, but I am leaning towards not adding this as an option. Any thoughts on this?
Also, anybody order extra seatbelt sets on these vans...or most of you traveling just as a couple with no additional passengers. Stock Platinum II only comes with two sets of seatbelts.
Also debating on Alcoa aluminum wheels. Are these worth it?
