Limp Mode - Causes?
labudski
Hello,
I have read that some things will make the t1n go into limp mode... Will all MIL "check engine" cause this to occur? Im trying to identify causes so that I can prepare for long trips.
Ive also read that while in limp mode you can only go 20mph while others indicate 55mph? does this depend on model or maybe code that was thrown?
So if you could list reasons why your t1n went into limpmode along with miles and resolution... That would be helpful to me!
Thanks,
Robert
2006 t1n roadtrek
New York
MillionMileSprinter
Formerly Type2Teach
Hello,
Thanks,
Robert
2006 t1n roadtrek
New York
These threads may already have what you're asking for.
https://sprinter-source.com/forums/showthread.php?t=17702
https://sprinter-source.com/forums/showthread.php?t=7173
Most LHM events limit power or possibly RPM. It doesn't limit to a specific speed which I have found. The MIL aka CEL being on doesn't trigger LHM of itself. The MIL is generally a warning to the operator that something is malfunctioning. Often that problem is related to emissions control related problems.
Edit: Composing while T2T posted.
