from this great comunity.
Exhaust change won't improve mpg.
, there was also a black film covering the whole inside you could write your name on it,"this is turning into a long story" anyway brought it to merc and they replaced the cabin filter
of course that didn't work, so i bought a length of pipe belong to the 313 models "its a 2.1 engine with the longer pipe that goes right to the back door. hard to believe but merc wanted €500 euro for the extra pipe
so i paid 40 euro instead at a local breakers,
. so now no smoke in your face first start in the morning and also none inside, as for noise its no different.This probably doesn't apply at all, but i remember years ago with one of the first turbo's out there on the Corvair, the muffler actually had to have back-pressure or the turbo would spin too fast. That's what waste-gates were for, i believe. Does this make a difference on these fancy computer run engines? Or am i just gettin' old and obsolete.
Why not?
The engine system is highly complex. The engineers who designed the system would have reduced back pressure if it improved mpg. Higher mpg is highly valued by the million buyers of this vehicle. Driving style and weight are the user controllable factors that will improve mpg. Messing around with the fundamental engineering is just going to cost money.
I'm new to the Sprinter, but have been messing with the 5.9L Cummins Ram combo. I have to disagree with svaric- Our friendly engineers are most confined by emissions. Then come the Noise, Vibration, Harshness, etc. This was gleaned from the engineer who designed the Cummins in the 2004.5 (300hp, 600 ft-lb.), Dennis Hurst. Sorry, but it's from the horses mouth. From my experiences, the only real need for a larger exhaust is if you're adding fuel. If you're adding fuel, you're and idiot if you don't have an egt gauge to see when to pull your foot out of the firewall because the aluminum pistons are about to be recycled. That sounded pretty harsh, but... egt= exhaust temperature gauge... Add fuel until the egt gauge gets too high, then do "something" to lower it, such as different computer settings for boost, timing etc. A stock engine has all that stuff designed into it without the need for an egt gauge. CederS- the corvair was a gasser- on a diesel, the only reason for an exhaust pipe is to "choose where the soot comes out" from Jerry Jardine of Jardine Headders. Go to 6 inches if you want to... but if the exhaust pipe isn't causing a rise in egt (restrictive backpressure making the engine work harder) don't change it. Ceder- you're right about a gasser needing backpressure for efficiency.I'd have to agree (hopefully it does) ........ I've known about this generally for some time ....... but having recently installed an EGT gauge really brought it home .....If you're adding fuel, you're and idiot if you don't have an egt gauge to see when to pull your foot out of the firewall because the aluminum pistons are about to be recycled. That sounded pretty harsh, but... egt= exhaust temperature gauge... Add fuel until the egt gauge gets too high, then do "something" to lower it, such as different computer settings for boost, timing etc. A stock engine has all that stuff designed into it without the need for an egt gauge.
Personally, I think the issue is too complex to take the risks.Hi guys- here's a newbie who is going to do some mouth-shooting.I'm new to the Sprinter, but have been messing with the 5.9L Cummins Ram combo. I have to disagree with svaric- Our friendly engineers are most confined by emissions. Then come the Noise, Vibration, Harshness, etc. This was gleaned from the engineer who designed the Cummins in the 2004.5 (300hp, 600 ft-lb.), Dennis Hurst. Sorry, but it's from the horses mouth. From my experiences, the only real need for a larger exhaust is if you're adding fuel. If you're adding fuel, you're and idiot if you don't have an egt gauge to see when to pull your foot out of the firewall because the aluminum pistons are about to be recycled. That sounded pretty harsh, but... egt= exhaust temperature gauge... Add fuel until the egt gauge gets too high, then do "something" to lower it, such as different computer settings for boost, timing etc. A stock engine has all that stuff designed into it without the need for an egt gauge. CederS- the corvair was a gasser- on a diesel, the only reason for an exhaust pipe is to "choose where the soot comes out" from Jerry Jardine of Jardine Headders. Go to 6 inches if you want to... but if the exhaust pipe isn't causing a rise in egt (restrictive backpressure making the engine work harder) don't change it. Ceder- you're right about a gasser needing backpressure for efficiency.
Hope my first post didn't sound like a rant. This forum medium is probably the best method us "end users" have to find out what to expect from our purchases, or pre-purchases, down the road. Thanks to the folks who put the Sprinter-Forum together!
Greg
