Dash brake light wont turn off
sanmr004
i got a 2006 dodge sprinter and the brake light on the dash came on i have replaced the master and checked the speen sensors but cant seem to figure out why the brake light is on the fluid has been checked and the brake lamp switch as well
if anyone has any idea i am open to suggestions to figure out why this light is on and to get it off Thanks
:thinking::thinking::thinking::idunno::idunno:
sailquik
sanmr004.... Did you replace the brake pads front and rear?
Are you sure the emergency brake handle is all the way down and unlatched?
Also check that the brake light switch is correctly adjusted.
Roger
sanmr004
yeah all pads are in the green and sensors are all good
the switch had been adjusted yes
and the e-brake is all the way down
sailquik
Cool!
Just checking to get the easy to overlook/easy to check stuff out of the way!
Roger
