zen bicycle
anybody have a T1n high top inside in CAD? I am about to start designing the interior and it sure would make things a lot simpler long wheel base single wheel preferred, but not choosy on that.
Thanks
Thanks
Maybe you have managed to get acrual dimensions in some vector file?The roof outline of the grabcad models for the 170" early in this thread were wrong. Unless you get one that was done very well or directly from MB, you will only be able to use it for planning, not to CNC cut to fit. Here is a 3D printed section from the CAD file compared to the real roof section. It's way off in places. I tweaked a piece of the model for this section for my purposes, but to fix the whole thing would be very difficult.
Regards,
Mark
No, I 3D printed sections, measured the gaps with calipers, tweaked the model, step and repeat. The grabcad models from 2014 are nowhere near correct. I extensively used 3D printed, cardboard and plywood models before cutting or making the parts for final installation. The CAD model was useful to describe the design but was not accurate enough to make anything using it.Maybe you have managed to get acrual dimensions in some vector file?
Maybe you still have these measurements? Would be nice if you could share them.No, I 3D printed sections, measured the gaps with calipers, tweaked the model, step and repeat. The grabcad models from 2014 are nowhere near correct. I extensively used 3D printed, cardboard and plywood models before cutting or making the parts for final installation. The CAD model was useful to describe the design but was not accurate enough to make anything using it.
Regards,
Mark
